King Pin replacement
Old 09-18-2009, 06:34 PM
LotusJoe's Avatar
LotusJoe
LotusJoe is offline
I am in the process of rebuilding the the king pins on my 1961. Any suggestions on how to install the new bushings if you don't have a press. Also where might I get a reaming tool for the bushings?
Thanks
Joe
Old 09-22-2009, 05:30 PM
francobones's Avatar
francobones
francobones is offline
Hi, my suggestion is to take it to a garage/repair shop (not sure what you guy's call it in the US), the mechanic who did my kingpins had to borrow a heavier duty press (5 ton I think) as he couldn't do it with his one, I don't think they are an easy job but someone here might know better.
Frank
Old 09-23-2009, 11:58 PM
66gpw's Avatar
66gpw
66gpw is offline
Vintage -vans has a few posts of the subject. where guys have trouble areas and what is needed to be done. Do you go with nylon bushings or brass. With bras you need to have it reemed and with nylon they can be pressed. The joys of removing it yourself or having a shop do it.
I just suggest checking the site out and see if their forums can help withan answer.
bphirt1
08-16-2015 09:27 AM
Santiagoeford
13
07-19-2015 01:27 PM
1970f100guy
04-25-2014 07:20 PM
CustomCab60
12-29-2007 06:46 AM
blue 62
06-26-2007 04:16 AM
Quick Reply: King Pin replacement
