bad blue smoke broblem -blow bye
i changed the distribuator on my truck because of that litle box on the side went it was esier to chande the hole thing i did then some how we screwed the timing up it wouldnt start we moved it around intell the truck would run it is still off but the problem is i am getting alot off blow bye out of the hose that comes of off the oil cap ould it be because the timing is off because it never done this befor-it is a 1991 ford f150 4x4 5.0 with 131000 kmh i would really appreciate the help
Sorry to hear of your blow-by issue, the guys in this forum should be able to help with it.
....Welcome to Ford-Truck Enthusiasts!
take the plug out of the passenger front and put your thumb over the spark plug hole. have somone crank the engine in short bursts until the compression pushes your thumb out of the way check your timing marks, adjust your distributor to #1. its as close as youll get without a timing light
did you replace the cap and rotor? i was under the impression that you bought a new one. it could have something to do with you putting the used crown vic icm in there. its probably the same part but thats something you want to check beforehand. autozone can test it and they sell one for like $30 and they have the nutdriver that fits in the holes its called a "ford ignition control module tool" they let me use it in the store last time- dont forget the grease. (next time use a sharpie to mark were everything is and you dont have to adjust the timing afterwards.)
