I have a '91 250 with a 5.8 & manual trans. My buddy has a JET Ford Module, Part# 89109 sitting around. Would it be worth putting on my truck? All I have is a K&N & an aftermarket exhaust..
Most will tell you that they are no good... but I haven't dealt with them. If thats the right module, then sure, give it a shot like White 97 was saying. Remember you should run 89 octane with it. You may have just as much luck bumping the time, tough.
Yeah. what was said above. dont waste your money. I just pulled on out of my lightning. All it did was advance the miming and make it ping. I took it out and set the timing to 14* and i runs a lot better and no more ping
