03 Navigator - interior lights won't turn off???
So, I have no idea what is up - the interior lights will not go off. Car running or not. The only way to get them off is to turn the rocker switch all the way until it clicks them off, but then there are no lights and all dash lights are on the dimmest setting... If you leave them off for a while then turn the rocker back on (about 10 minutes or so) they will not come back on as they should until a door is opened. Then voila!!! they stay on again... Anyone have any clue??
Is the switch bad? I've also noticed that the on-board computer display continuously shows a door open even though all doors have been verified closed...are they related and what would cause the open door issue?
Thanks all! This is our first Navigator!
Your door switch is stuck. Spray a lot of WD-40 into the door latch, then open and close it many times. That usually frees up the stuck switch.
V8SHO
1997-2006 Expedition & Navigator
01-23-2024 06:38 AM
2003, 99, continental, enthusiasts, expedition, f150, f350, ford, interior, lights, lincoln, navigator, turn, turning, wont
