Need help 1966 240 45000 miles
I came across 1966 240 out of a car has everything on it from the transmission to the carb. Was told it was replaced with a big block V8 At 45000 thousand miles.
Can I get a accurate compression reading from it sitting on a pallet?
What would be good compression range?
Thank you
Vincent
Thank you
Vincent
There is a lot of missing info,how long has it set,was oil put in the cylinders,does it have ancient oil in it,was it in the weather?You would be checking it at a very poor time because you don't know what is on the cylinder walls or on the valves and seats.If you do,pull all the spark plugs and make sure it has oil and wire the throttle plates open.If nobody put oil in the cylinders and you get maybe 90 or 100 and they are all pretty equal,my guess is that would be good,considering,but if you get a low cylinder,is it a bad valve or an old mouse nest under an exhaust valve?I would drop it in something and get it running,then check things out.It doesn't take long to hook up an older points engine just to run it,and after you burn the cobbwebbs out of it and every thing settles in a little,you can see what you really have,including oil pressure.
You may be able to.Make sure it has oil in it,this will also refresh the coating on the bearings at a low rpm.You may also be able to take a small,bright flash light and see a little of the valve edges thru the plug holes.It's worth a try,but if you get a bad reading on a cylinder,don't pronounce it dead,it will just take more investigating.
I went out to check the engine out it is a 300 6 1975 model.
Pulled the plugs and verified the stroke. 4 inch
Had been sitting a year.
It turned over by hand with plugs out.
Has oil in it.
He put oil in the cylinders before it sat up.
It sat in his garage covered up the hole time.
He thought it was a 240.
The starter was dragging so could not do a compression test.
I told him was not sure about buying it.
He said make offer, gave him 100.00 and left with it.
Has oil in it.
Hey,if that motor has 45k on it and the trans and you turned it by hand with out plugs,you probably stole it! If the guy put oil in the cylinders,it must have been worth it for him to take time to do it.A good tip is to use 2-stroke oil because it will burn out without fouling your plugs(just in case you ever have to do it).For $100 you can afford to check things out good.Don't forget about those rusty oil pans, it's killer if you have to replace it in the truck.Have fun with your new toy!
vincenthp
08-31-2009 08:08 PM
