PSD is still a POS
PSD is still a POS
OK went in to get the CPS recall done. Ran OK but I think they stuck a different tune into it as well. But after fueling up and going to a meeting last night the truck started that damn stalling thing again.
I am convinced it's fuel delivery so the tank is coming out this weekend. I can only imagine the crud I will find after 10 years and 231,000 miles.
It would say on the work order if they did that. They don't to anything at the dealer without recording it. If you're going to drop the tank, do the in-tank mods. It would be quickest to order the kit from ITP Diesel. And that moves any filtering to outside the tank so the tank never has to come out again.
I was initially thinking the IPR, but that doesn't sound like it. Sounds like an electrical connection which you probably already figured that out. It shouldn't be too hard to create the problem in the driveway withthe engine running and start playing with wires until it acts up again. There is a wire on the IPR that does come loose that can cause it to stall. The IPR is in the valley of the engine behind the HPOP reservior on the drivers side. Vibration and sudden turns that cause it to act up causes me to think it's electrical. It may be fuel related too though.
My truck now has 323,000 mi. fuel tank never dropped but i always have used a fuel conditioner. Just recently I ran some of this:
http://www.algae-x.net/pdf/AFC_Binder.pdf
The Detroit Diesel mechanic suggested I try it before i drop the tank..
So far I've noticed a change in performance.
The HPOP reservoir is on top of the engine in the front. It's that rectangle iron box that you have to look over in order to see into the valley from hell. The High Pressure Oil Pump is in the bottom of that box. The IPR is also at the bottom of that box too. It's on the back side, on the bottom, close to the drivers side head of the engine. Check the wire on the back of that thing. It has a tin nut that is known for coming loose. Be careful, it can be stripped out easily.
acronyms from the tech folder = https://www.ford-trucks.com/forums/4...re-on-fte.html
No, it's an internal leak with oil going where it isn't suppose to. Like I said, when this happens, it usually shows its ugly head when the truck is warmed up and the oil is thined out from the heat. It slips around the o-rings easier when warm.
OK tank is out nd fuel is drained. Inside is spic and span.
HOWEVER the suction screen was broken off and laying in the bottom of the tank. and the little orange rubber check valve looking thingy hasa tear in it. Parts on order with the dealer should be in by lunch.
Didn't get a chance to look at IPR wiring as I had to get grass cut while it wasn't raining.
So what is the big plastic round thing that connects return line to supply via a hose. Should I replace that hose as it is pretty hard.
Gonna do that Harpoon thing to the fill and vent tubes.
Instead of install new parts, you should rip that damn filter off the intake, and do the "hutch" intank mod. Go to either ITPdiesel.com or Dieselsite.com and look up the intank filter mods, you can do it yourself with some 3/8" brake line and some brass fittings if you don't want to buy it.
