map sensor
Old Sep 14, 2009 | 04:56 PM
yeldarb82's Avatar
yeldarb82
map sensor
<HR style="COLOR: #ffffff" SIZE=1> <!-- / icon and title --><!-- message -->
ok heres the problem when I unplug my map sensor the truck runs good but not great when i put it to the floor and let off then go again i only have about half the power untill i shut the truck off and restart it. If i plug the map sensor in i have almost no power so i bought a new map sensor still runs the same. AE shows no problems. boost is usually 15-16psi its a 96 powerstroke canada truck that never made it there any one have any ideas??
Old Sep 14, 2009 | 05:07 PM
Cuda_jim's Avatar
Cuda_jim
You say AE shows no problems, does this mean no codes or....
Did you watch the MAP PID while all this was going on?
Have you checked the small rubber line going to the MAP for pin holes, cracking ect?
Boost seems OK, could be higher.
Check the Fuel Pressure:
If it's time for a fuel filter now's a good time.
FP @ idle
FP under a load
FP after you let out of it.
This will require some rigging so you can drive it with the FP gauge in place.
Old Sep 14, 2009 | 05:16 PM
yeldarb82's Avatar
yeldarb82
fuel pump is brand new as of last wensday map line was replaced when i did my boost gauge the truck has had the problem since i bought it the truck also had a bad fuel pump when i bought it so it masked this problem but i got the truck for $3500 about a year ago with 170000 4wd crewcab
Old Sep 14, 2009 | 05:18 PM
yeldarb82's Avatar
yeldarb82
ae shows boost increase with the map sensor pluged in no codes or check engine light unless i unplug a sensor
Old Sep 14, 2009 | 07:14 PM
Alaskan 350's Avatar
Alaskan 350
The preasure you see on your ae should be more than atmospheric preasure if you are getting boost. At idle you should see 14.8 or so then when the turbo kicks in should go up from there ie 15 pounds of boost would show 29 on your scanner
Old Sep 14, 2009 | 07:30 PM
yeldarb82's Avatar
yeldarb82
Thanks for the info i do know the differance between psia and psig I am a service tec for a large mech contractor i am still baffeld by why the map being plugged in kills my hp and when i stomp the accelrator to the floor with the map unplugged it does the same thing . If i dont throw it to the floor with the map unplugged it runs fine but still lacking some ponys but it will still pull a 15k trailer
Old Sep 15, 2009 | 01:20 PM
Hussler's Avatar
Hussler
Sounds like the classic bad MAP sensor. But you have good boost and did replace the sensor.
What does AE report for boost (running)?
What is the part number on the Ford MAP sensor?
Many look alike, plug in, don't CEL but just won't work properly.
Old Sep 15, 2009 | 06:04 PM
yeldarb82's Avatar
yeldarb82
could a bad exhaust back pressure sensor cause the computer to think it has an overboost situation?
Old Sep 15, 2009 | 06:18 PM
Hussler's Avatar
Hussler
No ...
But the EBPV by the turbo could be closing. That would cause about 1/2 power. Do you hear a hissing sound when the problem occurs? If so disconnect it by the two wire connector just below and in front of the turbo.
Old Sep 15, 2009 | 06:30 PM
yeldarb82's Avatar
yeldarb82
nope took care of that problem long ago but even with it unplugged it still shows a reading of 53
Old Sep 15, 2009 | 06:41 PM
Hussler's Avatar
Hussler
What is the part number on the MAP sensor????????
Old Sep 15, 2009 | 06:54 PM
yeldarb82's Avatar
yeldarb82
O.E.M. #F4TF-9J480-AA the part came from autozone Part Number:
SU2348
Old Sep 15, 2009 | 06:57 PM
yeldarb82's Avatar
yeldarb82
with it plugged in it usually only lets me run up to 12-13 then the truck shifts to next gear
Old Sep 16, 2009 | 06:56 AM
Cuda_jim's Avatar
Cuda_jim
SU2348
Maybe you have the wrong MAP sensor
The OEM Part# is F4TZ-9F479-A
poetbig
Aug 3, 2016 04:00 PM
rickdavis81
May 12, 2016 04:34 PM
Mwvwaw
Jan 8, 2016 03:05 PM
nwjones18
May 7, 2015 07:44 AM
KB300
24
Mar 7, 2012 08:58 PM
