play in the middle drive shaft bushing
Old 09-13-2009, 08:36 PM
hertz1438's Avatar
hertz1438
hertz1438 is offline
i have a f350 srw longbed and in the middle of the drive shaft that goes to the rear there is a bushing of some sort. i was under there and checking some other things and noticed some movement in that bushing . it looked liked it was smashed down also the boot was gone off of that area also. should that be tighter??
Old 09-13-2009, 08:39 PM
mxracer3276's Avatar
mxracer3276
mxracer3276 is offline
Is this the bushing youre talking about:
If so this is called you carrier bearing and there should not be play in it.
Old 09-14-2009, 06:31 AM
hertz1438's Avatar
hertz1438
thats the one...is that easy to change out?
Old 09-14-2009, 06:40 AM
mxracer3276
I had to take mine to a shop due to the fact that i dont have a hydralic press which is needed to press the bearing back on. The play is alright for now but it will probably lead to a very loud squeal and get very annoying and you will want to change it out anyway.
Here is my thread on it: https://www.ford-trucks.com/forums/8...riveshaft.html
Old 09-14-2009, 08:17 AM
big poppa's Avatar
big poppa
big poppa is offline
Had mine change out a while back also, no press here either. I had a slight squeek and rubbing sound coming from under there.
Old 09-14-2009, 08:22 AM
03_PSD's Avatar
03_PSD
03_PSD is offline
I'm getting a humming noise at speeds of 65 and above, I'm wondering if this is the culprit?
Old 09-14-2009, 08:27 AM
mxracer3276
Hey Glenn, i may be wrong but when this thing is on its way out, boy you know it. It squeals quite loud. Mine did it at all speeds, slow or fast.
Old 09-14-2009, 08:33 AM
03_PSD's Avatar
03_PSD
03_PSD is offline
Ah, good to know. I need to figure this out, I'll have to do some detective work.
Old 09-14-2009, 06:38 PM
big poppa's Avatar
big poppa
Hey Glenn, while your investigating under there, take a look to see if any of these weights came off the drive shafts, noise and shaking or rattling are some of the symtoms
Old 09-14-2009, 06:40 PM
03_PSD's Avatar
03_PSD
03_PSD is offline
Will do Mike, thanks!
rpatrick
07-11-2011 06:46 PM
Ardvarg
08-27-2010 09:06 PM
xlt4wd90
Aerostar
24
03-08-2010 04:57 PM
postalxj
12-19-2009 01:10 PM
martin441
01-03-2009 08:00 AM
Quick Reply: play in the middle drive shaft bushing
