2000 F150 5.4l 2WD electrical issues?
A few weeks ago, the truck would try to start sitting in the driveway with me in the living room and keys in my pocket. Also the radio and dash lights would come on and go back off. Found that part of the ignition switch had broken off, there was a plastic part sitting on top where the key cylinder goes and had a metal clip touching metal. Fixed it with gorilla tape and thought it fixed the problem for a few weeks but now when the engine is running, the starter tries to engage for a few seconds and quits. Also the radio and dash lights go off then come back on. Would appreciate it if anyone has a clue what's going on.
Since all the main components have been replaced, then the remaining possibility is faulty wiring or the ECM. If the strange problem occurring is random then a short somewhere is likely occurring. Difficult task is trying to find it. I don't have any clever suggestions to ease that task. Maybe someone else will offer a tip.
If there is a pattern to the occurrence of the problem it is possibly the ECM. Checking the ECM will likely require a high end diagnostic scanner. May need to see a dealership for that.
It is impossible for the PCM to cause this set of symptoms. GEM, fuse box or wiring are among the possibilities.
Does the phantom cranking and the dash/radio malfunction occur at exactly the same time or a random different times?
Exactly which dash lights are exhibiting the behavior?
Is there an aftermarket or dealer installed remote start installed in the truck?
Have you pulled the kick panels and inspected the grounding lugs for loose or corroded connections or body rot?
I've removed the fuse box and there was moisture inside once I removed the two big plugs. I also pulled the GEM off and looked at the circuit board, did not see any moisture on it. I put a generous amount of dielectric grease on the connectors and cranked it back up. I had the dash apart so the headlight switch was unplugged but the display on the radio kept going out and coming back on and the starter kept trying to engage again. Possibly the GEM is bad? The grounds under the kick panel look good, no rust. Tempted to start pulling plugs apart and applying dielectric grease to them one at a time. I also have some Flex Seal and the next warm day remove the windshield cowl and see if it is leaking. Otherwise, I am at a loss.
The following users liked this post:
Collision
03-10-2016 08:33 PM
MrJames159
1997-2006 Expedition & Navigator
02-01-2011 10:42 AM
