front hub assmebly
front hub assmebly
While doing brake pads on the front of my 01 F250 4wd (with 150000 miles on it) I noticed the hub and tire can move up and down. My immediate thought was a bad wheel bearing in the hub. The axle moves up and down about 1/2" at the seal at the knuckle/axle tube. From what I have seen from searches this is normal. I did some searching here and found guzzle's instructions for servicing the spindle/needle bearings and pulled the hub. The spindle looks good and so do the needle bearings. In fact, from what I can tell the unservicble bearing in the hub seems fine. Everything seems hunky dory.
My current thinking is if I have it torn down this far might as well do ball joints, but this is not my question. Oh, and I checked the ball joints and they seem tight with no play.
My question is this. If everything seems fine as far as the hub is concerned, is it normal to have this much play? I have never notriced this before when rotating tires, etc. and just find it odd to have this much movement without finding anything obviously "bad". I am inclined to put it back together once I have greased the spindle bearing and serviced the auto-locking hub.
Any comments, questions, insults , or suggestions would be greatly appreciated.
Thanks
Dwight
AND, I don't know who Guzzle is, but he is priceless. His write ups have been invaluable so thanks Guzzle.
Thanks
Dwight
No, play is not normal and something is wearing out. That being said, those unit hubs can go for thousands of miles and be worn. Not that I am advocating running them till they fall off, but from a purely speculative standpoint, I would say that from the time they begin to fall out of spec in terms of "play", to the time the start growling so bad you think they are gonna rip clean off is in the tens of thousands. We have several 4x4s in our fleet with over 200k miles on them and I have seen those bearings take some massive abuse. Often the don't start acting up till the truck is halfway across the country and you can't do anything about it. I have seen then them drive up to 2500 miles on a bearing once it starts growling before we could get it swapped out.
The moral of all this? The bearing IS likely starting to go bad and you should get it fixed, but it is not something you need to park the truck tomorrow over.
I just replaced my hub this weekend due to the excessive play. I had to also replace my u joint. So, with the stub shaft being separated from the rest of the axle I was able to insert it into the new hub and the old hub for comparison. The shaft had the same amount of play in both. Since I already had the new hub (great deal on CL) I put the new one in. I think the new knuckle seal really helped mine too. And may have been the only part needing replacement. Although, the truck did handle the bumps better on the test drive. It didn't want to wander at all. So, two things I learned this weekend: 1 - replacing the hub is really not that hard to do. 2 - if you have to pull the new hub again to put the brake dust shield on the right way, it slides right out once you get all the bolts off. DOH
Kirbys73F100
05-23-2013 01:06 PM
mechelement
10-12-2009 01:26 AM
52caddy
13
04-27-2009 11:40 PM
mongo75
1999 to 2016 Super Duty
05-30-2007 03:56 PM
JKBridges
03-05-2007 05:57 PM
