'05 Grille Badge Removal
Hi all,
I've got an '05 F350. Enough stones have hit the big FORD oval emblem on the grille that it looks bad. I have a replacement emblem, and examining it, it looks like it's a push-on type deal - it has two triangular plastic tabs that look like they lock into the grille if it's just pushed into place.
I don't want to take the grille apart to get to the back side to release any clips or whatever is back there if I don't have to.
My question is, does anyone know if I can just pry on the old emblem until it breaks off, or will that damage whatever part of the grille holds the emblem on?
Thank you!
Thank you!
I was looking at my emblem and didn't really figure out how it is supposed to come out. Didn't look too hard, because I wasn't ready to actually take it out. But it is extremely easy to take the grille off, and I would do that no matter what, just to make it easier to work on the emblem.
Remove the grille by removing 4 screws across the top, tip the grille out 10 degrees, then reach behind it with a screw driver to pry the 5 spring clips loose across the bottom. It's a 2 minute job, not counting collecting your tools.
Please let us know how the emblem comes off. Mine is looking sorry too.
Thanks, bpounds - heck, that sounds easy - maybe just tilting the grille forward will allow enough room to get to the back side of the emblem.
It's a shop truck, and the boss took it home for the weekend to do some chores, so I won't be able to get to it next week, but I'll let you know how it goes.
Yes, take the grille off, much easier. I do remember seeing a nut on the back of mine, but I only glanced at it, so I cant remember exactly. Take the grille off, it will be easier either way...
Speaking of emblems, I need to replace the one on my 05. My 01's still looks like new, Ford's "cheapening" is getting irritating. Anyone have any leads on a grille emblem that will last longer like my billet badges?
I was looking at mine the other day because it is faded and peeling and it looks like just a nut and some plastic clips...
the grille comes off easy! 2 mins, just the hand full of screws on top then lean the grille forward and reach down inside from the top using a flat head screw driver and push down on the metal clips at the bottom.
has anyone painted or polished thier stock emblem? if so post a pic!! I dont want to spend money replacing the stock emblem because in the future I want to get a billet grille...
