351M - Is there any point in going 4 barrel with my setup? Specs inside!
Hey guys,
I have a stock rebuild 351M and the 2V carb is causing me problems. Would I be getting much more power if I went with a 4V edelbrock carb/manifold setup with my engine? Looking for more power, but not wanting to just pour gas down the drain though either! Thanks!
Dual exhaust, Hedman long-tube headers, MSD ignition & coil.
Cam specs:CS1161R
Speed Pro Ford 302, 351 Cleveland V8 Camshaft Kit (Mild)
Duration @ 0.050"
Intake: 194
Exhaust: 204
Cam Lift
Intake: 0.265
Exhaust: 0.280
Valve Lift
Intake: 0.458
Exhaust: 0.484
Lobe Spread: 110
RPM Range: 1000 - 4000
Cam specs:CS1161R
Duration @ 0.050"
Intake: 194
Exhaust: 204
Cam Lift
Intake: 0.265
Exhaust: 0.280
Valve Lift
Intake: 0.458
Exhaust: 0.484
Lobe Spread: 110
GoinBoarding
89
02-23-2020 06:27 AM
cwaskoiviak
22
02-26-2018 10:12 AM
Justin73supercamper
06-08-2017 02:10 PM
MattMac
28
05-26-2017 08:32 PM
Christian
13
09-16-2002 06:02 AM
1978, 351m, 4x4, 79, barrel, cam, camshaft, carb, carbarator, carburetor, em4, f150, horsepower, hp, specs
