Rust on Frame and Springs
I spent 5 months at the beach at the beginning of the year (I know, I know. somebody has to do it) and the frame and the springs are speckled with some rust.
It appears to be mostly surface rust.
Should I care? Is it worth fixing. How would I fix it? I plan on keeping the truck till it dies.
Wash it good with some high pressure. Wally World has some spray paint cheap that will take care of it.
Sounds like you could blow the rust off and you'd be fine!!
I've wire brushed mine at least a couple of times and painted it and with our wonderful winters and salty roads, I'll be doing it again soon. Should have done it the beginning of summer, but haven't quite had the time.
It does make the truck look a lot better once you get it painted up, almost like it's new.
I'm tempted to use some of the rustoleum rust reformer, thinking it might slow it down, but that stuff's pretty expensive to put on the frame and then probably have it rust back off next winter.
That's a common product folks use on the oil pans. Haven't tried it myself, but from what I have read, it's great stuff.
I own a boat and trailer that gets immersed in salt water on a regular basis. I use a product called Corrosion X HD or Fluid film on all the springs and all non galvanized metal. These products seep into all the nooks and crannies to seal out the salt water, and stop further rusting. The trailer is now twelve years old and still in good shape.
Please you guys don't know real rust. I just wire brushed mine lightly to knock off the heavy scale and sprayed over it all with black Rustoleum. Unfortunately it's starting to rust through again now even without it being winter so some POR 15 may be the ultimate solution once the paint rusts off this winter.
waterfront
01-28-2022 09:14 AM
smashclash
06-07-2010 02:12 AM
Kalashtar
01-29-2006 02:32 PM
