Struggling with door lock removal
I was attempting to remove the door latch mechanism to repair the weak locking motor in my 2000 Excursion, and I got stuck on one of the linkages. I spent 45 minutes trying to figure out how to undo it with out breaking it before I gave up yesterday. The bottom horizontal linkage that goes to the visible lock latch (ie that which moves up and down in front of the window) was easy. The one that has me stumped is the vertical linkage on top that doesn't seem to have any obvious function. There is a plastic green sleeve on the bottom of it that holds on to a threaded connector rod, and I believe that this is what must be removed to release this linkage. But I couldn't figure out how to release it for the life of me.
Hmmm .... So it is the handle pull rod that was giving me difficulty. I assumed that I could remove the assembly without removing the handle from the other side of the door. I think that is an incorrect assumption. Thanks for the link. Those are very detailed pictures for door panel removal.
ya you don't need to take off the door handle or anything. what it is i think you are describing is the rod that goes to the key lock on the out side. and at the bottom of that rod where it attaches to the door lock assembly the rod is threaded, right.
if that is the rod you are talking about. then the plastic piece that the threaded rod goes onto bends in half. the plastic piece has two tabs on each side of it. if you feel them bend them up a little and then the one side of the plastic piece will fold back and the threaded rod will just fall out. it took me awhile to figure that out but once i did i can get the door actuators out in about 5 min now.
