3G Alternator Install With Pictures
#46
#47
I just scored a 3G from the Junkyard for 20 bucks. Clipped out the harness and 4 gauge charging wire to go with it. Chaching! it was 1/2 off day at the pick-a-part. It would have been cheaper than 20, but he charged me for the wiring harness. Oh, and i took it out of a Ford Windstar. It appears as if the van went to the junkyard right after a brand new autozone alternator was installed. It still has the sticker with the numbers on it, i wonder if i can obtain the warranty for it. Baller on a Dollar!
#48
#51
#53
This is a great thread. Currently my 86 4.9L looks like it has a 2G. Not sure of amperage, but HAS to be low as this thing has headlights and heat and thats it!!
So are all of the 130A 3G's the bigger 8.25" case? I want to add electric fans and start wiring this thing on relays. Headlights etc.. Plus have room left over on alternator. The 130A sounds like it is for me.
Is there a direct bolt in 130A 3G?
Thanks!
Dave
Thanks!
Dave
#54
Dave,
The 2G is only about 60-65A
You are a little confused.
The 3G comes in two case diameters, 135mm (95A, 4 hole) and 148mm (130A, 2 hole)
Both sizes come in a few mounting styles.
7" C-C pivot (3.0V-6)
8.25" C-C pivot (3.8V-6)
Side mount
Odd front 'V' mount. (for Mod motors I think)
I made the mistake before -but now know- that the 4.9 mount takes the 8.25" C-C spacing.
Look for one from a '90-'93 3.8l V6 Taurus/Sable.
You will need:
A new charge cable with 175A fuse inline
To tap the adjuster ear of your new alternator to 3/8-16
To modify your current regulator plug as shown at the bottom of post #41
Change over to your current V-belt pulley. (add a shim washer so it doesn't rub the case)
Side mount
You will need:
Last edited by ArdWrknTrk; 01-11-2014 at 08:21 AM. Reason: Add info about what needs to be done to make it fit.
#55
I got this from Amazon;
Models:
Ford Car & Lt Trk
1990 Taurus 3.8L V6, Optional 130 Amp Unit, w/Internal Regulator
1991 Taurus 3.8L V6, Stanard 130 Amp Unit
1992 Taurus 3.8L V6, Stanard 130 Amp Unit
1993 Taurus 3.8L V6, Stanard 130 Amp Unit
1995 Windstar 3.8L V6, Early 1995
Lincoln Car & Lt Trk
1991 Continental 3.8L V6, 130 Amp Unit, w/Internal Regulator
1992 Continental 3.8L V6, 130 Amp Unit, w/Internal Regulator
1993 Continental 3.8L V6, 130 Amp Unit, w/Internal Regulator
1994 Continental 3.8L V6, 130 Amp Unit, w/Internal Regulator
Mercury Car & Lt Trk
1990 Sable 3.8L V6, Optional 130 Amp Unit, w/Internal Regulator
1991 Sable 3.8L V6, Stanard 130 Amp Unit
1992 Sable 3.8L V6, Stanard 130 Amp Unit
1993 Sable 3.8L V6, Stanard 130 Amp Unit
Replaces:
AC Delco
321-1305, 334-2009
Bosch Newman
AL7508N
Denso First Time Fit
210-5209, 210-5211
Ford
F0DF-10300-BA, F0DU-10300-BB,
F0DU-10300-BC, F0DZ-10346-B,
F0DZ-10346-C, F0DZ-10346-E,
F0PU-10346-AD, F58U-10300-AA
Ford Engineering
F0DF-BA, F0DU-BB,
F0DU-BC, F58U-AA
Motorcraft
GL-278, GL-301, GL-310
Models:
Ford Car & Lt Trk
Replaces:
AC Delco
321-1305, 334-2009
Bosch Newman
AL7508N
210-5209, 210-5211
Ford
Ford Engineering
F0DF-BA, F0DU-BB,
F0DU-BC, F58U-AA
Motorcraft
#56
Rick,
Side mount
Odd front 'V' mount for Mod motors.
You will need
Side mount
You will need
Ah yes, I thought that the 4.9 had the 7". Thanks!!! I will try and find a 8.25" for cheap. I am in no rush as the "Fire" alternator still works. I do like the "Ryan" install. I looked, and maybe I passed it, do they sell that as a Kit?
#57
#58
$81.60!!! Weird price, but cheap!!! I think this is gonna get bought!!!
New Alternator Ford Lincoln Mercury 3 8L DB Electrical | eBay
#59
#60
