What do you guys use for Reactor pumps?
The pump the I use is a Clearwater that I got off Ebay for $19.99. I have a questions related to the pump.
For methanol recovery, I heat up the processor to about 175 and let it run a few hours until the drip rate slows. Usually end up recovering about a gallon off of the bio. (35 gallon batches). The bio still smells fairly strong of methanol, so I need to get more out. (and use less Magnesol) However, if I heat beyond 175, the pump starts to drip. I think the seals can't handle it. I've run about a dozen batches so far.
I've read that I should be heating to 90C, or around 200 degrees. I heard Harbor Freight pumps are recommended, would it handle the heat better?
thanks,
Trent
thanks,
Trent
[quote=Rushmore X;7995573]The pump the I use is a Clearwater that I got off Ebay for $19.99. I have a questions related to the pump.
thanks,
I've been running the cheap HF blue pump for the past year and a half, and it's still running strong. Each batch is heated to 140f, and it usually runs for 2-4 hours total.
Not sure you would have much better luck with these. While mine doesn't drip, it does weep enough to have to wipe around the pump.
thanks,
No, I don't. I'm not yet convinced I want to go that route. I get decent wvo, and with glycerin pre treat, I go 18%-19% methanol single stage. For me it's about whether or not the added equipment and time is worthwhile.
thanks,
Trent
thanks,
Trent
Tom D
Bio-diesel, Propane & Alternative Diesel Engine Fuels
03-03-2009 06:40 PM
Rushmore X
02-16-2009 12:51 PM
CheaperJeeper
01-29-2009 03:53 PM
Rushmore X
01-26-2009 10:44 AM
Dave Barbieri
49
06-23-2006 03:30 PM
