Tis the season for coolent change
Well cold weather and winter isnt to far away now and i wanna change out my coolent before it gets here.Right now i have the green anti freeze in there and im tired of worrying about the sca's.Whats the kind i can use with out worrying about that stuff?Is it the final charge from wally world or the rottela?thanks
Final Charge and Rotella ELCs are the same. I would suggest you get four gallons of which ever ELC you can find locally in concentrate and go with it. Delo, Cat, Zerex, they all make HD diesel ELCs too. Just make sure you get at least 20 gallons of distilled water to get all that green stuff out...
Alternatively, you can go with the G-05 Gold Semi-ELC. It's a 100k mile coolant, and you don't have to check SCAs. But you still have to do a good flush.
EDIT: Beat me to it, Cluxy....
how long is the final charge good for?and do i have to use distilled water and can i use just regular well water?
this is the stuff that you want. it is extended life coolant. I think I used 6 gallons.. can't remember for sure. You have to do a real good coolant flush to get all that green crap out... It is real easy to do. Look up Gooch's coolant flush ... it is the best and easiest way to flush the system...
Another vote for the red CAT ELC extended life coolant good for 300k miles.
http://www.cat.com/cda/files/87058/7/elcfaq.pdf
I'd also put a coolant filter in while you're at it
http://www.dieselsite.com/index.asp?...WPROD&ProdID=8
Instructions
http://www.thedieselstop.com/forums/...ctions-163800/
Instructions
Thanks, think yall just saved my butt, least my truck
Just browsing through the threads when I hit this one. Found out earlier this week my new used truck was a cali truck with your help, now this.
Went out and looked at the trucks coolant, green..... Worse yet, looked really light in color. Put my handy ancient coolant tester in, good to +20 F. that isn't exactly going to cut it in Montana winters I am betting. Looks like I will be doing a major flush and putting real coolant in this weekend with the new glo plugs.
Thanks, Tom
Thanks, Tom
