Mustang II Rack
The short answer would be the one that TCI etc. sends with the cross-member when you order the kit. The long answer is that the racks when ordered from aftermarket suspension suppliers come (if required or you stipulate) with what they call “rack extenders” that make up for the increased track that is built into the cross-member kit. I don’t know what the 56 track dimension is (and too lazy to look it up) but the 51-52 comes out close to 60 inches (or stock) and the extenders make up the difference, most kits are using the newer racks with the v shaped input shaft. (90 t-bird???)
Thanks everyone for your input. What my situation is, I have a set of tubular A-arms and spindles for a Mustang II frontend that was pulled off a C#$^y truck. I traded some labor for them. The frontend had less than 1,000 miles on it. I am about to buy a cross member to put it in my 56 and being the tight screw that I am, I was wondering if I can buy the power rack cheaper at an auto parts store than from TCI. Again, thanks for the info.
Scott
Scott
Scott
Scott
Sam
I just bought mine from full tilt streetrods.
This is the place i have bought all my MII parts from.
The box that came was from a Carquest store (part number 22-202F)and they installed the extension kit, all set to install.
The total for me was 277.95 to my door.
I waqs told from some local places they wanted a core charge because i had none?
So i paid no tax because it was out of state and no core just 33.00 for the shipping.
Good luck!
Good luck!
hwyhogg
09-10-2015 09:20 AM
jrockdiddy
05-27-2015 02:22 AM
gt40racing
11-15-2009 08:47 AM
