'67 F-100 Project
#62
#66
Well, went out and took a good look at the cab yesterday, to see what I need for sheet metal. Definitively both cab corners. I probably don't have to, but I'm going to go ahead and pull the fron cab mounts and replace them, so I can clean up and coat under them. Since I'm pulling the cowl off to clean it out, might as well do the cab mounts. Looks Like I'm going to be going with Dennis Carpenter for the sheet metal replacement parts.
#68
Also, found a tranny, transfer case, and a motor to boot. I'm buying an 89 F-250 from a guy in west-central Nebraska. He just needed the rear end, so he's selling me the rest of the truck, for $350, plus the price of scrap for the rest of the truck. Nice thing is, I can take everything off of this truck that I will need, instead of having to run around salvage yards trying to find it all, like the clutch reservoir and lines, cross member, drive shafts, etc.
#69
#70
#72
#73
Pat, see you have not discovered nails yet...
Work bench carriage bolted together... Dolly lagged together...
But if it makes you feel better both look pretty hefty....
So am I reading this correctly... You spent the summer conning the woman to letting you keep it in the garage over the winter in stead of dragging it down the street to the storage building???
