Blinking Airbag
Old Aug 30, 2009 | 03:16 AM
broanderw's Avatar
broanderw
Blinking Airbag
99 Eddie Bauer it blinks 3times then 5times repeatedly five times then stays on. I've checked the connectors under the passenger seat seems to be intact?
Old Aug 30, 2009 | 06:52 AM
projectSHO89's Avatar
projectSHO89
https://www.ford-trucks.com/forums/6...-bag-code.html
Old Sep 3, 2009 | 09:41 PM
fiveohpoepoe's Avatar
fiveohpoepoe
Does it do it every time you drive? Mine will every now and then, but it just stays on. I will cut off the engine, then restart it. Maybe it resets whatever the issue is. Ive also had the samething with my 4wd light.
Old Sep 4, 2009 | 12:15 AM
alloro's Avatar
alloro
Code 35 does mean the airbag module has loss connection to the passenger airbag. Take a look under the passenger seat for a 2-wire connector (sometimes white tipped) and make sure it's plugged in tight. That's the circuit that's giving you the trouble.
