driveshaft vibration
Old Aug 29, 2009 | 09:18 AM
Lostinky's Avatar
Lostinky
1960 F-100 223 w/3-speed manual, all original. 146,000 miles, driveshaft has lots of play at slip yolk/tailshaft, vibrates at higher speeds. Cannot find this bushing on any internet parts lists or sites. Any help on IDing this part before I tear into it? Do I need a press to replace it?
Old Aug 29, 2009 | 09:56 AM
gdgerland's Avatar
gdgerland
Sounds like your U-joints are bad. I don't know of any bushings on either end of the drive shaft. U-joints should be available at any just about any parts house. A press is not required to replace the U-joints.
By the way, welcome to FTE. Glad to have you on board.
Gil
Old Aug 29, 2009 | 11:22 AM
ALBUQ F-1's Avatar
ALBUQ F-1
I take it your trans has an extension housing? I wouldn't be surprised if that part is still available at Ford dealers and trans/driveline repair shops, I believe it was used for a very long time. Check with NumberDummy here on the forum, he can help with a number.
