What should my next upgrade be?
I have been thinking of doing the tank mods and regulated fuel return next. I was thinking of using both of ITP Diesel kits. You guys think that's a good decision and I would also like to do the fuel delete at the same time but what kind of filter will I replace that with.
Here's what I used when I did my in tank mods.http://www.guzzle7pt3.com/hutch.php .This is a good mod to do for getting the air out of the fuel.
I picked up a small in line filter for in the line before the fuel pump.
I like ITPs reg return,Just to much $$$ for me.If you do the RR you will need a 2 micron filter between the fuel pump and the engine.I don't have the filter numember I'll see if I can find it.
Yes,these are good mods to do! I just have to do the reg return yet.ITP has good products as well as http://www.riffraffdiesel.com/mm5/merchant.mvc?
I installed the ITP fuel tank/pre-pump kit a few years ago and ITP's regulated return when I did the injectors. Great kits - would do it again.
Definitely get on the pre-pump kit, it's a must do mod IMO.
Brad, Did you mean to say you need the filter if you do the bowl delete not the regulated return?
You may want to consider changing out the fuel pump if you do the intank mods and use the canister (screw on) type filter. There have been a couple of cases of the stock fuel pump going south after the mods. This, we think, is due to the pump suching through the extra finer micron filter after having xxxxxxx miles on it. I would go with a Walbro pump.
Thats it Rich!I Forgot you can get one and keep the fuel bowl.
There is a walbro pump that bolts right into the stock location.
So starting from the tank I would get the ITP in tank mod with the external filter it comes with to the walbro pump to the ITP regulated return kit w/ fuel delete bowl. Would I need another filter between the pump and regulated return kit. Would I benefit from adding a AirDog with other modifications I'm doing and where would it go after the pump or before.
If you get a airdog set up you can skip the intank mods,remove the stock fuel pump,install the air dog,and install the reg return W/fuel bowl delete and your good.The airdog will remove the air from your fuel as it pass through it.So you would save yourself some trouble by doing the airdog,just spending more money.
I would still drop the tank and do the harpoon mod.Makes filling the tank all the way full easier.
There is a few kits on the market for our fuel systems.Call the dealers and ask questions also(remember there salesmen also) and they can tell you how it all works.
Search through the fourms or ask more questions on here.A bunch of guys have done DIY RR set up here.
Yes it does look vaguely familure.......
Hey Rich good to see you around! It is a pretty straightforward swap. IIRC you can cut off the factory pushlock fittings and use hose barbs. It is a much better pump and the price makes it much sweeter too.
