Competition Diesel racing, sleds, dynos, power tuning and max performance.
powerstoke vs chevy 1500
Old 06-19-2008, 03:15 PM
kupaa's Avatar
kupaa
kupaa is offline
this guy wants to hook up bumper to bumper and do a tug-o-war,should i be afraid of him?He has a 9 inch lift and 38 swampers and 4:88 gears.
Old 06-19-2008, 04:16 PM
fbilly420's Avatar
fbilly420
fbilly420 is offline
dont even worry. You will pull him around like nothing. If he doesnt break an axle.
Old 06-19-2008, 04:44 PM
DAFBFD58's Avatar
DAFBFD58
DAFBFD58 is offline
I dont see a problem, just make sure you have a long enogh chain because once you tighten that chain his lift will give him a slight leverage on you. Second just do this 4x4 low 1or 2nd gear, hold the brakes and spool up a little, once he brakes loose his tires trying to get you to move, let off the break and take him for a ride!
Old 06-19-2008, 06:23 PM
kupaa's Avatar
kupaa
kupaa is offline
yeh baby.cant wait
Old 06-19-2008, 09:04 PM
rockstate45's Avatar
rockstate45
rockstate45 is offline
Hey, safety first... put a towel over that chain/rope in case it does snap.
Now, you should drag him around like a ragdoll.
Like Ryan said, longer chain should be a bit better. You'll be pulling his rear end down, effectively giving him traction. Likewise, I suppose he'll be pulling your rear end up, limiting your traction.
It's all about weight and traction to win these things. Do what Ryan said about letting him break traction first and you'll win hands down.
I don't know your mods in terms of lift and/or tires but you should beat him pretty easily. You have tons more power than he does.
-rockstate
Old 06-22-2008, 03:08 PM
strokin'_tatsch's Avatar
strokin'_tatsch
strokin'_tatsch is offline
get you a couple elevator weights and either put them in the bed of your truck or hide them by mounting them under your truck. i would say 2 or 3 would be enough to pull him around. LoL
Old 06-29-2008, 07:36 PM
Raider50's Avatar
Raider50
Raider50 is offline
yah with the mods you have on your truck kuppa, and the weight and power advantage I wouldnt worry about it at all. cant wait to here the story on how you destroyed him.
Old 07-05-2008, 09:57 AM
IcemanV8's Avatar
IcemanV8
IcemanV8 is offline
It's all going to come down to traction. OR who breaks something first. I'm with the rest, I don't know what tires you have.
Personally, I think people are giving you the win a little too easy, unless they know what tires you have and I don't.
If you are doing this off-road, either in mud, dirt, or grass, if you have some stock-*** street tires he's going to drag you around. Pavement would be a different story, but even then, if his tires are gripping and yours aren't, nothing else matters.
You have the weight advantage, that's a big part of it, also, but I think the proper tires for a specific application is more important (unless you are talking about 5,000 pounds vs 50,000 pounds).
Also, like mentioned, don't use a short rope. If he's a lot higher than you, you'll be pulling his tires down and he'll be pulling your tires up.
Old 07-07-2008, 12:26 PM
Pkupman82's Avatar
Pkupman82
Pkupman82 is offline
Chevy 1500? It it one of those 88 and up "rail dragger" style trucks? If he still has stock axles, he'll break something for sure before he even moves you. A 1/2 ton with 38s... some peoples kids especially if he still has the IFS front end on it. If he is running the set up I think he has, he will be leaving broken driveline components on the pavement. When are these Chevy boys gonna learn
Old 07-10-2008, 03:59 PM
Dustball8504's Avatar
Dustball8504
Dustball8504 is offline
if it helps...i just hooked up to my buddys duramax last week and had no problems tugging him anywhere i wanted....i can't imagine a half ton being any harder to pull, even with a lift and tires.
Old 07-11-2008, 08:10 AM
SUPERDUTY_untouchabl's Avatar
SUPERDUTY_untouchabl is offline
Video this, the chevy is going to break. 4.88 gears mixed with 38" tires and moving in the opposite direction there spinning. that just spells disaster...
Old 07-13-2008, 12:46 AM
79f-250custom's Avatar
79f-250custom
79f-250custom is offline
u should be able to beat him. i hooked up to my buddy in his 91 chebby scotsdale 2500 on 33's. i was in my Powerstroke"details in sig" i did have a 4x4 fourwheeler in my bed but i did beat him when he was in 2wd and 4 wd. my 75 highboy had a harder time pulling him around and thats on 39's.
just wait till he spins and you will get him.
Mitch
Old 07-25-2008, 01:22 PM
secondarychaos's Avatar
secondarychaos
secondarychaos is offline
I invision a broke axle. that big of tires with those gears? Definately have a camera and dont forget to post results!
Old 08-10-2010, 06:12 PM
Pkupman82's Avatar
Pkupman82
My only advice to you is to bring a broom, dust pan, and a video camera!
Old 08-30-2010, 10:54 AM
Brown Falcon's Avatar
Brown Falcon
Brown Falcon is offline
So? What are the results???
Quick Reply: powerstoke vs chevy 1500
