What's normal boost just cruising?
Old 08-27-2009, 09:02 PM
msmith53
msmith53 is offline
msmith53 is starting off with a positive reputation.
Having my gauges put in tomorrow, and when I get the truck back, I'm just wondering what's normal boost range for just driving down the hiway, not under load or pulling anything? Thanks for any input. Got an e99 motor with stock turbo and injectors, AIS intake and new 4" turbo back exhaust.
Old 08-27-2009, 09:09 PM
7.3 Rocket's Avatar
7.3 Rocket
7.3 Rocket is offline
7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future
With my stock turbo I'd see 5-10 pounds, but I usually drive the truck pretty hard.
mueckster's Avatar
mueckster
mueckster is offline
mueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputation
Depends, I see anywhere from 0-4 psi @ 60-65mph on flat ground.
Tenn01PSD350's Avatar
Tenn01PSD350
Tenn01PSD350 is offline
Tenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud of
About anywhere from 3 to 6 psi just cruising at about 70. Think of it as a fuel demand/consumption meter too. There will be a load at highway speed simply from rolling and wind resistance. 3 is about right for level and up to 6 on a grade. It will drop to zero going down hill.
Old 08-27-2009, 09:11 PM
Tenn01PSD350
Originally Posted by mueckster View Post
Depends, I see anywhere from 0-3 psi @ 60-65mph.
You are not going to drive down the interstate at speed with zero boost unless you let up or are going downhill.
Old 08-27-2009, 09:15 PM
mueckster's Avatar
mueckster
That's driving to and from work for about 20 miles. No interstate. There's a few stops and several curves. I don't run a constant speed, but I can hold a steady speed without raising the needle.
Old 08-27-2009, 09:21 PM
msmith53
msmith53 is offline
Thanks guys...great answers that really help. Now I know what to look for. Glad I asked, cause if I was seeing just 4 or 5 psi when cruisin' I would have thought it was low out of ignorance...but now I know better. Never had a diesel before!! All new to me.
Old 08-27-2009, 10:31 PM
BobbyDiesel71's Avatar
BobbyDiesel71
BobbyDiesel71 is offline
BobbyDiesel71 has a very good reputation on FTE.BobbyDiesel71 has a very good reputation on FTE.BobbyDiesel71 has a very good reputation on FTE.
msmith, have you met any of the Iowa peeps yet?
I am sure they are great at helping out a fellow Hawkeye!!!!
how are things at Lake McBride?
Old 08-27-2009, 10:48 PM
Tenn01PSD350
Sounds about right then Roland. It can get down close to zero at times just cruising, but anytime you try to change what is happening it will build some boost, then drop off.
Old 08-27-2009, 10:53 PM
SuperDoodie's Avatar
SuperDoodie
SuperDoodie is offline
SuperDoodie has a very good reputation on FTE.SuperDoodie has a very good reputation on FTE.SuperDoodie has a very good reputation on FTE.
I only see 0 - 3 psi as well.
Old 08-27-2009, 10:55 PM
Bigcat350's Avatar
Bigcat350
Bigcat350 is offline
Bigcat350 has a very good reputation on FTE.Bigcat350 has a very good reputation on FTE.Bigcat350 has a very good reputation on FTE.
With the 4:10's you will be slightly higher also.( SLIGHTLY) on the high way.
Old 08-27-2009, 11:26 PM
Tenn01PSD350
At what cruising speed?
Old 08-27-2009, 11:46 PM
Bigcat350's Avatar
Bigcat350
On I-65 and on a good flat stretch doing 75-MPH with cruise on I see 4 psi boost and 525 EGT
Old 08-28-2009, 07:08 AM
msmith53
msmith53 is offline
Probably around 65. With the 4.10 rear, going much faster really sucks the fuel.
Hey Bobby,
Haven't met any fellow Hawkeye's yet in person, but have gotten a lot of good advice from Smokin', Farmboy (Adam) and several others from the great state of Iowa. Joined the local FTE chapter, and hope to meet some of them in person one of these days.
Old 08-28-2009, 07:14 AM
Izzy351's Avatar
Izzy351
Izzy351 is offline
Izzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud of
Different turbos will have different numbers. When I had my stocker, I was running about 4-5 psi & 600 deg EGTs on flat road at 70mph. With the van turbo, my EGTs dropped 50-100 degrees, and my boost is down to about 2-3psi under the same conditions. What that tells me is the stock turbo was becoming too much of a restriction even at 70mph! Why else would the EGTs go *DOWN* when the boost drops?
Quick Reply: What's normal boost just cruising?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
