1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Would like opinions on u-joints
Old 08-27-2009, 12:04 PM
iron1951's Avatar
iron1951
iron1951 is offline
I need to replace the seals inside the "pumpkin" on my front end of my 2004 F250. So since I am taking everthing apart to get to them, and replacing all the seals on the way in, I figure I might as well do the u-joints on the front drive shafts too.
My question is should I stick with the stock Ford u-joints or should I go after market? Are there some aftermarket u-joints that are superior to the Ford or are the Ford ones the best to go with? Should I get u-joints with grease fittings or if they have grease fittings would it be too difficult to grease them?
Would appreciate some opinions from those who have been there before. Thanks
Old 08-27-2009, 12:23 PM
DAVE67FD's Avatar
DAVE67FD
DAVE67FD is offline
IMO the Spicers cant be beat. If you are a hardcore 4-wheeler or put alot of stress on the 4-wd system go with the non-greaseable joints there overall stronger units. If you do normal everyday driving or light abuse go with the greasable joint. The non-grease joints may not outlive the greaseable but will in heavy duty abuse.
Old 08-27-2009, 12:49 PM
skip mitchell's Avatar
skip mitchell
skip mitchell is offline
took the words out of my mouth I like the spicer joints as well.
Old 08-27-2009, 01:24 PM
EXv10's Avatar
EXv10
EXv10 is offline
Personally; I would get the cheapest ones I could find and not even that if they are still good. If you spend a lot of time in a foot of water it won't matter what is in there. If you do "normal" driving the front joints rarely go out and it's not an easy job to replace them either. The reason they give little problem is because they are not even turning unless you are in 4WD, also when they are rarely in 4WD each one only carries 1/3rd of the total burden. But, if you do a TON of 4 wheeling with oversize wheels I would recommend the Spicers with zerks. (after the old ones are shot).
PaulTMurphy
04-20-2017 12:15 PM
carl2591
10-07-2015 01:51 PM
Budman1962
08-30-2015 09:50 AM
$undance
1997 - 2003 F150
06-12-2012 03:34 PM
MikeFlorida
05-13-2007 06:52 PM
Quick Reply: Would like opinions on u-joints
