87 5.0L Engine/Transmission Removal
Old 08-25-2009, 06:28 PM
rgraham3
rgraham3 is offline
rgraham3 is starting off with a positive reputation.
I'm about to rebuild the 5.0L engine in my 87 F150, and plan to remove the AOD automatic transmission for overhaul at the same time. Is it better to pull them together as an assembled unit, or to remove the engine and transmission one at a time? Any hints or suggestions before I begin.
Old 08-25-2009, 06:49 PM
Old93junk's Avatar
Old93junk
Old93junk is offline
Old93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputation
Pull them both as a unit, saves a lot of work. Plenty of room forward to pull with the rad. removed.
Old 08-25-2009, 07:20 PM
rgraham3
rgraham3 is offline
Thanks, that confirms what I was planning to do, but you never know what hidden surprises might be there. Guess it's time to go to work.
Old 08-28-2009, 04:14 AM
underwaterboy82
underwaterboy82 is offline
underwaterboy82 is starting off with a positive reputation.
i would pull them together also, although i never got a chance to do it that way, i always was rebuilding one or the other..
jake
Old 08-28-2009, 09:22 AM
rgraham3
rgraham3 is offline
jake
Thanks, Jake. I'm in the process of pulling them now. Everything is disconnected and they should lift out today.
Old 08-28-2009, 11:43 AM
underwaterboy82
no problem
Old 08-28-2009, 03:09 PM
Eddiec1564
Eddiec1564 is online now
Eddiec1564 has a great reputation on FTE.Eddiec1564 has a great reputation on FTE.Eddiec1564 has a great reputation on FTE.Eddiec1564 has a great reputation on FTE.
Also take the hood off, that gives the engine lift more lifting room without hitting the hood.
gbrewer
05-04-2015 02:52 PM
Luke79
1978 - 1996 Big Bronco
06-14-2012 10:07 PM
4X4mac
06-13-2010 11:14 PM
david00f150
11-11-2008 02:04 PM
Bertha1
09-08-2007 04:43 PM
Quick Reply: 87 5.0L Engine/Transmission Removal
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
