Please help troubleshoot this
Hi there,
Judging from the video below, does it means that the water pump need to be changed?
https://plus.google.com/photos/11140...88664626868750
or may be this link will work better:
https://picasaweb.google.com/1114098...90557257205938
I was in process of replacing the radiator, which I bough with your help, and found that the cooling fan is moving...
Thank you for your help!
I can only speak from my own experience, but I used an off-the-shelf replacement from NAPA. It's served me well for the last two years, as have almost all parts I've ever bought from them.
In short:
I did mine with napas shelf option, the cast iron pump they had for like $28. Worked out just fine. Didnt put sealant on any of the bolts, personally. If your gonna have the water pump out as well, consider changing the thermostat. I didnt and managed to get it out with the new pump on, after I had a problem with overheating, but it would have been alot easier with the pump off. Typically you change the thermostat when you change the pump.
vidaliaman
15
02-08-2017 07:38 AM
restoringmy46
01-26-2009 06:43 PM
