Specs.
Old Aug 24, 2009 | 10:06 AM
Ooftus's Avatar
Ooftus
Specs.
Does any one know of online spec. info. regarding the 390 FE ?
Head bolt, intake torque etc.......Thanks
.........P.S. What is a bump side ? ?
Old Aug 24, 2009 | 11:07 AM
whitetrash's Avatar
whitetrash
Welcome to FTE; bump side refers to the body styling on the sheet metal of these trucks, 67-72 had the protrusion (bump) and the 73-79 were concaved (dent side).
I just rebuilt my 390 using the book “How to Rebuild Big Block Ford Engines” by Steve Christ. It has all the specs you are looking for and I could post them for you when I get home from work. But I am sure someone will come along prior to that help you with all the info you need. If not I will check back this evening and see if you still need some help. There is and engine section on this site as well.
Old Aug 24, 2009 | 06:56 PM
Ooftus's Avatar
Ooftus
bump n dent
Never heard the body styles refered to that way, makes sense, I'll have to remember that.
Found all the info., just had to do a little running arround.
Appreciate it.
________
'69 Ranger
'72 Ranchero
'78 Peterbilt
