04 Valet Bulb
04 Valet Bulb
For the life of me I cannot figure out how to get to this bulb. Its located under the mirror[passenger side] Just to be clear, the valet light I am talking about is when you unlock/open the doors. He are a few pics. If anyone can help, I would greatly appreciate it. I HAVE TRIED THE SCREW SHOWN IN THE PIC WITH THE MIRROR FOLDED IN
Mirror signal pod removal
Remove the screw you can access with the mirror folded in. The entire signal assembly will pop out - the outboard part of the pod is held in place by a metal clip. You might have to insert a flat screw driver between the bottom of the mirror glass and the housing to press the clip in enough so the signal pod will pop out. Shine a light in the housing and you should see the clip.
I found out the hard way there was a screw holding the inboard part of the pod in place.
You don't need to remove the mirror glass if you don't want to risk breaking the glass. I did that too....
Once the pod's out you can change the puddle lamp bulb and the turn signal bulb. Do both since you have it apart.
