Cool Tools
Cool Tools
I don't remember if it was here or another site but, someone talked about how he made his own brake fluid pump for changing and bleeding brake fluid.... I poked around the net and I saw them selling for $60 to $100.......
Well I just put one together for my F250 that cost me less than $20.
Here it is....
I haven't tried it out yet, hopefully later this week but, I did make it so I can change out the reservoir cap in order to do other vehicles.
$8 pump
$2 reservoir cap from junkyard
$4 tubing
$4 connecting parts.
I have some epoxy in my toolbox so the total was under $20.
Any more cool tools out there?
Here it is....
$8 pump
$4 tubing
I too am building one of these, but my project stalled because I cannot locate an inexpensive pressure gauge. I see you don't have one, and I guess they're not necessary, but I would like one. The directions I'm using said a good working pressure is 15lbs., but I can't find a small gauge that measures in that range for less than $12.-20.00.
If anyone can suggest a supplier for such a gauge, that'd be really appreciated.
Thanks,
Big Six
Thanks,
Big Six
Str8racing:
Did you mean you wanted instructions on how to build one?
Here you go: http://www.bmw-m.net/TechProc/bleeder.htm
And here's one to buy: http://www.tptools.com/p/658,313_Pow...eder-Kits.html
I'm not recommending you purchase the latter, as I've got no experience with that--I just included it for a price reference, for motivation to build your own--LOL.
Elderstarr,
I will check out their shipping costs, from Canada--thank you!
Peter
Elderstarr,
Peter
Thanks,
Big Six
Thanks,
Big Six
Plus you have to figure the application too. Since you're not on your back twisting the wrench every ten seconds, you'll be able to watch the whole process easier. The original poster used a two liter soda bottle to catch the old fluid with a wire coat hanger holding it upright at the wheel. I'm using an opaque coolant jug so I'll have to keep an eye in the clear tubing from the bleed valve.
But figure when it's time to release pressure you just twist the pump top and everything is fine. It's a closed system so unless you go spastic on pumping up pressure you can't screw it up. You'll start with the brake right under the reservoir so you can gently practice the technique before moving on....
But if you really need a gauge, try old or cheep bicycle pump gauges. Someone you know will probably have an old trashed tire pump gauge needing the be tossed. You just have to ask so you can be there to catch it.
