Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.7L Power Stroke Diesel
Reload this Page >
Order banks are open for the 6.7L!!!!!!!!!!
Old 08-21-2009, 10:30 AM
UGA33's Avatar
UGA33
UGA33 is online now
UGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud of
Found this on the garage. Oh yeah! No more manuals though
http://www.thedieselgarage.com/forum...ad.php?t=83788
Old 08-21-2009, 10:55 AM
Kep4's Avatar
Kep4
Kep4 is offline
Jδger
Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.
I truly hope it's a success from not only a reliability standpoint but hopefully fuel mileage and power curve.
This is an interesting item from the build sheet:
X3J 3.55 ELOCKING
Sure would be nice if that means an electric locker for the rear axle is available from the factory.
Old 08-21-2009, 11:19 AM
Maxium4x4's Avatar
Maxium4x4
Maxium4x4 is online now
Maxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputation
This will be an interesting truck when it starts to hit the lots
Old 08-21-2009, 12:23 PM
UGA33's Avatar
UGA33
UGA33 is online now
You got that right . I hope my new job is turning out enough cash flow so I can buy one and not be divorced.
Old 08-21-2009, 08:19 PM
powerstroke72's Avatar
powerstroke72
powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
X3J 3.55 ELOCKING
I saw that too Russ and was pleasantly surprised. The other thing I saw on there was that is had front side airbags. I also saw this on page two with regard to the E-locker 3.55:
• Electronic Locking Rear
Differential — uses a true mechanical
connection to lock the left and right
axle shafts together so both turn at the
same speed with the same amount of
torque.
• Designed to solidly lock the rear axles and differential when the customer wants
• Controlled by the Electronic Shift-on-the-fly instrument-panel-mounted switch
• An electromagnetic coil activates a mechanical lock inside the rear differential housing to solidly lock the rear axle shafts together
• Once the axle shafts are locked, torque is equally distributed to each rear axle shaft
Old 08-21-2009, 09:35 PM
mizzitch
mizzitch is offline
mizzitch is starting off with a positive reputation.
The dually rear fenders are obviously different from the current SDs...but what is up with the rear fender flare on this Super Cab SB? Maybe a SRW with a wider rear track?
http://www.leftlanenews.com/cars/ima...rd-f-250-4.jpg
Old 08-21-2009, 09:40 PM
powerstroke72
If I had to guess, it's probably some of the fake cladding they put under the camo covers to mask the actual body panels. They routinely do this to keep folks from knowing what is really underneath.
What I find more encouraging than anything in that photo is the fact that they have Michelin tires on that truck. Hopefully they'll switch to Michelins and stop using the Crapinentals.
Old 08-22-2009, 08:36 AM
gotdiesel's Avatar
gotdiesel
gotdiesel is offline
gotdiesel is starting off with a positive reputation.
So when does this mean people can actually start ordering trucks?
Old 08-22-2009, 08:53 AM
Toreador_Diesel's Avatar
Toreador_Diesel
Toreador_Diesel is offline
Toreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputation
I'd say so, but they probably have a Specific release date for it.
Checked Ford's website and they don't have it listed yet, so I assume you can only order from the dealer as I'm sure they don't want horsepower and torque numbers, as well as features leaking out....yet.
Old 08-23-2009, 04:24 PM
UGA33's Avatar
UGA33
UGA33 is online now
I can't remember where I read it but the lines fire up sometime in Feb of 2010. This is one of those "I know a guy who knows a guy who knows a guy deal" but I was talking to a guy that owns a diesel performance shop at the local sled pulls last night and Ford is firing up the lines to produce 75 trucks in the next two weeks for promotion purposes. He said the guy told him as soon as the trucks come off the lines they will go right back in and will be gone over with a fine tooth comb. The guy I talked to is suppose to be getting a VIN number of one of these trucks so that when the time gets near he can hopefully snag one up. We shall see
Old 09-04-2009, 07:07 AM
F350-6's Avatar
F350-6
F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Is it me or does the hood look like it's about 8" higher than the bed rails?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
