318.9hp and 721.4tq
08-17-2009, 10:54 AM
on
318.9hp and 721.4tq
Ran the dyno in Cedar Bluffs,NE on sat and I believe I pulled down some respectable numbers. Only had the truck for six months. Next purchase is a cold air intake(any suggestions)and a snow water/meth injection. Am I on the right path or should I start somewhere else? Guide me all-knowing ones. Thanks Murph
08-17-2009, 11:43 AM
What mods do you have now?
08-17-2009, 12:06 PM
on
banks exhaust turbo wheel trans command six gun dp tuner and gauges
08-17-2009, 12:55 PM
Jeez! What year is the truck? That's really hot numbers for just those mods. What dyno did you run on?
08-17-2009, 01:11 PM
on
Quote:
Originally Posted by
diesel-fitter-bum01
You running both these?
08-17-2009, 01:34 PM
03_PSD
My thoughts exactly, unless the 6 gun is his gauges?
08-17-2009, 02:05 PM
on
six gun and DPtuner with gauges 01 excursion
08-17-2009, 02:15 PM
diesel-fitter-bum01
I guess you know you can't stack chips on our trucks. The DP-TUNER will over ride the six gun.
08-17-2009, 02:23 PM
on
That's what I was thinking Rick.
08-17-2009, 02:59 PM
miller_feed
I think you can, just not with a DP Tuner because of the reason you pointed out.
08-17-2009, 03:12 PM
on
08-17-2009, 03:16 PM
on
Why would you want to stack any chip with the DP? Dp is way better than the six gun period!
08-17-2009, 03:21 PM
diesel-fitter-bum01
can't or not supposed to
You can stack them, but only the DP-TUNER will control the PCM and the other chip will be doing nothing.
08-17-2009, 03:30 PM
miller_feed
x2. Your 6 gun is doing NOTHING except taking up space.
08-17-2009, 03:42 PM
on
it does make a difference if i turn up the six gun
