Wrench party in Sept?
I won't be able to make it this weekend.
We made reservations at Branson, and yesterday we all came down with the stomach sickness. And to top it off the reservations can't be canceled, hopefully we'll all feel at least a little better by then.
The Superchips stays in the console of my truck anytime you need/want it.
Alright, sounds like it should be fun. The drivers floor pan is in, but it is going to need some tweaking....Dave, have the BFH ready! lol We are going to try a different welder for the passenger side, we will see if that works. Tomorrow I am going to hook all the pedals up and be ready for Sat!
Well it is time for an update on the tranny! I added more fluid and it was still making some noise inside. I was getting ready to plan a time to pull the tranny back out and shim it up properly. Well I was driving Mater around the block to strech his legs and I thought, I am gonna run in 4-high to lube up the x-fer case. Well I went to pull it into gear and the stick didn't move! WTF!!! I decided to see if it would go into neutral, maybe that would unstick the case. I stuck it in what I thought was N and the truck jumped forward when I let the clutch out. So I pused the stick forward one more and let the clutch out, it didn't move. Well come to find out I have been driving around in 4-high this whole time. I took mater down the road to check out and see if the noise was there.....nothing! I am guessing with the case in 4wd it was binidng up the tranny for some reason. I haven't tried to drive in 4-high to see if it makes any more noise like that. Maybe when the rain stops I will try again. And for those of you who weren't there and didn't get to see the syncro carnage, here is a pic!
