Help...A/C retrofit Gurus
Old 08-15-2009, 12:55 PM
buzzurd's Avatar
buzzurd
buzzurd is offline
89 F150..5.0Litre.Did a 134a retrofit and can't get cold air.Here's where I'm at.
New Compressor
New Reciever/Drier
New Blue Orifice tube
Flushed entire system
Passed leak test
I have charged system anywhere from 75 to 85% of R12 capacity (52oz.)
Low side running at 55psi
High side running at 250psi
ambient air 85 degrees
65 degrees at vent with max A/C on
Any Ideas?????
Old 08-15-2009, 03:56 PM
subford's Avatar
subford
subford is offline
Sounds like and over charge.
Low side should be about 42 PSI.
Old 08-15-2009, 03:57 PM
subford's Avatar
subford
subford is offline
Old 08-15-2009, 05:51 PM
jas88's Avatar
jas88
jas88 is offline
Yeah, 55 is too high on the low side but I would expect more than 250 on the high side. I think your orifice tube is too big, I used a red on on mine. Isn't it red-white-blue from smallest to largest?
Old 08-16-2009, 07:26 AM
buzzurd's Avatar
buzzurd
buzzurd is offline
If in fact it is red/white/blue that may be the problem.Can anyone verify the red/white/blue thing?As mentioned I installed the blue.
Thanks
Old 08-16-2009, 08:23 AM
subford's Avatar
subford
subford is offline
Ford Colors Orifice Tube sizes:
Blue = .067
Red = .062
Orange = .057
Green = .052
Brown = .047
The only white one I know of was used in the GM line and it was .072.
Ford F-series:
81-86 Blue (R-12)
87-90 Red (R12)
91-93 Blue (R-12)
94-96 Red (R134a)
97-98 Blue (R134a)
Old 08-16-2009, 09:22 AM
buzzurd's Avatar
buzzurd
buzzurd is offline
Thanks Subford.....so which would you reccomend for the retrofit?
Old 08-16-2009, 10:29 AM
subford's Avatar
subford
subford is offline
Sounds like you need the red one.
Old 08-16-2009, 06:41 PM
AaronOregon's Avatar
AaronOregon
AaronOregon is offline
Sounds like it has to much in to me too. I just did my '89 retro this last week and went blue orifice and I am right at 44 degrees idling and 38 degrees driving. Feels GREAT. My system only took 3lbs. bone dry.
Aaron
UNTAMND
09-28-2016 10:18 PM
timbersteel
06-15-2014 06:50 PM
PStruwing
08-06-2012 12:32 PM
valleyd01
2004 - 2008 F150
06-21-2012 05:00 PM
1993Exploder
08-02-2004 03:13 PM
Quick Reply: Help...A/C retrofit Gurus
