Waterless Wash?? Any input?
I used to have a 1992 white S-10 and I used waterless wash on it. It worked great. I never had any problems with it scratching it. If I had any dirt build up on it, I would rinse it down first with a water hose and try to wash off as much dirt as possible. Ofcourse, I used that stuff every weekend on my truck when I had it. It looked like it rolled off the showroom floor when I sold it in 1996. The waterless wash that I used had silicones in it and made cleaning very easy when used on a regular basis.
Bronco894x4
Bronco894x4
Thanx for input. I used befor I went to the beach this weekend. Usually the salt air and sand do a number on the finish.When I returned i just rinsed the truck w/ a hose.Truck looks newly washed. I'm out of the sample I had but I'm going to puchase more.
LouV14
LouV14
I use a product called "Meguiar's Quik Detailer Mist & Wipe" It doesnt scratch and it makes it look like its just waxed, it will also tell you when its time to rewax your car by the way it starts to wipe off the longer it takes to wipe off and buff the closer you need to wax again, I love it.
LouV14,
You'll find the more you use the waterless wash, the less you use. I was also wondering if you are using the latest version of the wash that comes in an aerosol? I still have a 32 oz. bottle of the original. I'll probably try the aerosol after that runs out. The guy I buy mine from says you use even less with the aerosol.
Rodeo
Rodeo
