propane, cng, or e85 in my 2000 v10
Old 08-23-2009, 07:02 PM
rancid's Avatar
rancid
rancid is offline
Looking at running an alternitive fuel and I'm leaning towards e85. But just wondering what everybody thinks. My truck is 2000 f250 4wd ext cab shortbed with a auto.
Old 08-27-2009, 08:48 AM
gasman6674's Avatar
gasman6674
gasman6674 is offline
I know there are cng and lpg kits availible for your unit. The only issues would be tank size (bed or underbody mount) and age of the engine. If you are planing on doing or have done a rebuild then go for it. I have a flex fuel sport trac and I have run E85 in it and was pleasantly surprized with proformance but my milage drop and avg of 3 mpg
good luck
Old 08-31-2009, 01:24 PM
jimandmandy's Avatar
jimandmandy
jimandmandy is offline
E85 is way easier to do, CNG the most difficult. What is the motivation, environment or economy? CNG is the cleanest by far, but most limited as far as range and refueling infrastructure. LPG costs as much as gasoline or diesel around here, so there is no payback.
Jim
Old 09-08-2009, 11:06 AM
Elderstarr's Avatar
Elderstarr
Elderstarr is offline
Stock compression ratio is 9.2:1 which is not enough to gain any mileage or power gains on CNG or propane. I wouldn't do it unless propane is REALLY cheap in your area.
To gain from CNG or propane, you can shave the heads as far as possible to bump C.R. While doing that, get hardened valve seats installed in your head. This will probably cost $1000, but check into rebate programs in your area.
Easiest & Cheapest: E85.
Old 09-17-2009, 12:41 PM
fraso's Avatar
fraso
fraso is offline
Which conversion you go with really depends upon the price of each fuel in your area, its availability, and how much fuel you go through annually for its payback.
There are V10-specific LPG and CNG kits available but none are EPA-certified so they would be difficult to be commercially installed in the USA. CNG systems are generally not available to the DIY installer so CNG conversions are even more difficult. I have no idea if there is an EPA-certified E85 kit available but I would expect that it would easier to DIY install it.
mizzitch
Modular V10 (6.8l)
20
05-19-2023 02:56 PM
Pat54632
22
11-04-2016 11:15 AM
NC1Caldwell
1997-2006 Expedition & Navigator
05-09-2015 10:40 AM
bmac4020
07-27-2008 10:13 PM
jd730d
05-06-2007 05:48 PM
Quick Reply: propane, cng, or e85 in my 2000 v10
