DP Tuner F5
Old 08-16-2009, 04:52 PM
zx250's Avatar
zx250
zx250 is offline
Of the next Riffraff East
Unless you have power to the switch, it's not goning to start. Make sure it's plugged al the way in both the chip and the switch. I'm thinking one end is not plugged in good.
  #32
Old 08-16-2009, 06:40 PM
DP-Tuner's Avatar
DP-Tuner
DP-Tuner is offline
PREMIUM SPONSOR
Pay close attention to page 4 of our instruction manual. If there is no power getting to the switch it will not light up. Double check the seating of the knotches. If their good,make sure it is not in position 0.
__________________
Jody & Diane Tipton- DP-Tuner®
FTE Legacy Sponsors since 2006
Custom tuning for 7.3l, 6.0l, 6.4l,6.7l, Ecoboost,
Get Tuned! 828-221-0076 ext. 802
Become our Facebook Fan
  #33
Old 08-16-2009, 06:45 PM
jkidd_39's Avatar
jkidd_39
jkidd_39 is offline
Pete, don't worry.. i'm having the same chip issues.. I'm off to the store for some duct tape.. we are gonna make it stay! Good luck buddy
  #34
Old 08-16-2009, 06:51 PM
7.3 Rocket's Avatar
7.3 Rocket
7.3 Rocket is offline
To be 100% honest I was not the one to clean the connectors. Nick was doing that while I was searching for Clay for some stuff. Clay looked at it later on and said the pins were cleaned off well possibly on the verge of being cleaned too much. Could that be an issue?
What makes me think it's an issue with the switch is that the connections at both end are in facing the proper way and very well seated and the chip seats well enough to not let the truck start when it's installed.
If it wasn't making good contact then why would the no-start feature work?
  #35
Old 08-16-2009, 06:53 PM
zx250's Avatar
zx250
zx250 is offline
If you are not getting any numbers to light on the switch, then you are not getting power. I can pull my switch off and it will enable the no start.
  #36
Old 08-16-2009, 06:54 PM
jkidd_39's Avatar
jkidd_39
jkidd_39 is offline
When you turn on the key does a little light in the bottom right of the number screen flash once?
If not you are not in no start.
I have found that my chip is on my PCM right.. it's just the cord that is having trouble staying in the chip.. at least in my situation
  #37
Old 08-16-2009, 06:55 PM
big poppa's Avatar
big poppa
big poppa is offline
I just hope the pins don't need to be retinned for proper contact, worst case senario, hope its not.
  #38
Old 08-16-2009, 06:58 PM
zx250's Avatar
zx250
zx250 is offline
Just don't forget to remove the keys anytime you mess with the chip/pcm. You don't want to take the chance of frying you PCM.
  #39
Old 08-16-2009, 07:02 PM
7.3 Rocket's Avatar
7.3 Rocket
Every time, Barry. They live in my back pocket every time I touch the chip.
I'll try again tomorrow and tape that stupid cord on to make sure it doesn't come loose. This is getting a little old.
  #40
Old 08-16-2009, 07:03 PM
zx250's Avatar
zx250
zx250 is offline
Pete, If I were you, I would take the keys out. Pull the black plastic off the back of the pcm. Pull the chip. Make sure the cable is seated good, replace the chip making sure it sets in good and should be even across the back. Next, check the plug on back of switch, make sure it's seated good. Key on, then wiggle the plug on the switch. I wonder if your attempts early on may have damaged the chip somehow. Not sure what putting it in upside down would do, if anything.
  #41
Old 08-16-2009, 07:06 PM
maevans's Avatar
maevans
maevans is offline
Pete
If you think it would help, I will send you my extra F5 switch to try and see if it could be the switch. Just let me know.
  #42
Old 08-16-2009, 07:09 PM
zx250's Avatar
zx250
zx250 is offline
Super offer Mark. Reps sent.
  #43
Old 08-16-2009, 07:11 PM
zx250's Avatar
zx250
zx250 is offline
Don't give up Pete, I know you will figure it out and it will be worth the wait.
  #44
big poppa's Avatar
big poppa
Originally Posted by maevans
Pete
Very nice of yaa Mark.. Just repped yaa so the next time.
  #45
Old 08-16-2009, 07:15 PM
7.3 Rocket's Avatar
7.3 Rocket
Barry it never actually went on. I was looking at the heat sinks thinking WTF how does that seat onto the PCM then I turned it over and saw the actual contacts.
So I've got an idea but I don't know if it'll work or not.
If I had a test light and a good ground could I install the chip and then touch the test light to the cable end and see if it'll light and figure out the issue?
If I'd had the time it would've been easier at RRE because I could've tried my switch in another truck and eliminated that issue.
Unfortunately I do not have a multimeter readily available to me.
Quick Reply: DP Tuner F5
