Whats Up ? Power Stroke Leaking Fuel
Old 08-12-2009, 09:07 PM
KY Ridge Runner
KY Ridge Runner is offline
KY Ridge Runner is starting off with a positive reputation.
Love my '95 Power Stroke, but this a.m. I cranked it up and while it was warming up I smelled fuel, lots of it. It was pouring out the bottom of the truck. Turned it off, raised the hood and there was fuel pooled up on top of the motor. What happened? Any ideas will be helpful and appreciated.
Old 08-12-2009, 09:13 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Diesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant future
Sounds as though your fuel filter housing is leaking , or possibly your drain valve(yellow lever) o-rings are leaking. but for a more powerstroke question go here https://www.ford-trucks.com/forums/forum170/
Old 08-12-2009, 09:33 PM
hi mile ford
hi mile ford is offline
hi mile ford is starting off with a positive reputation.
problem solved
i have a 97 stroke 7.3 and mine did the same thing the manuel fuel pump has a weep hole in it and after so long it starts to leak then one day boom fuel every where. i put a new one in mine in about a hour and a half. how many miles on the truck?
Old 08-12-2009, 09:38 PM
KY Ridge Runner
There are 200,000 miles on the truck...
Old 08-12-2009, 09:39 PM
hi mile ford
one more thing if you do change it change the lines going in and out of the pump they are cheap and you will be better off in the long run.
Diesel_Brad
Manual fuel pump? What the hell is that? You mean mechanical fuel pump?
Old 08-12-2009, 10:11 PM
KY Ridge Runner
Thanks for the info. I'll let you know what I find and how it goes
Old 08-19-2009, 09:26 PM
hi mile ford
they make both a manual and a mechanical pump the mechanical you can turn up to use more fuel but the manual i dont think you can.
Old 08-20-2009, 06:28 AM
Diesel_Brad
No you are wrong!!!! The last year for a mechanical injector pump you could "turn up" was 94.
And 94-97 had mechanical engine driven fuel pumps. 99-09 have electric frame mounted fuel pumps
Old 08-20-2009, 12:15 PM
hi mile ford
my truck is a 97 and the only reason i say that is cause they gave me a mechanical pump when i went to replace mine and it was the wrong one i had to specify manual fuel pump at the auto parts store thats the only reason i say that. i understand what you are saying its a engine driven pump and it has no electronics going to it
Old 08-20-2009, 08:25 PM
Diesel_Brad
If they gave you a injector pump instead of a fuel pump they are *** holes. The injector pump is approx 1500 while the fuel pump is 150...there is a big difference
2006FordF250
08-22-2014 05:16 PM
Mike Wall
17
12-03-2007 09:29 PM
88763739
09-05-2007 05:40 PM
LANCE KOBUSCH
01-19-2007 08:23 AM
MW95F250
General Automotive Discussion
15
03-15-2004 11:27 PM
Quick Reply: Whats Up ? Power Stroke Leaking Fuel
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
