I got a 76 F350. It will only start in drive. I was thinking it was the neutral safety switch but I dont see one on my automatic transmission. Anyone got any ideas?
Think I should replace it then if it only wants to start in drive? Or is there some kind of adjustment on it?
The NSS is the same 1967/77 F100/350: C7TZ7A247A (Motorcraft SW600)
Is the problem with the switch or something else?
The switch fits on top of the steering column's mast jacket, and it's controlled by a spring steel selector lever (looks like this: --{ ) that fits thru a hole in the mast jacket, then snaps onto the shift tube.
The pointed end of this lever fits into the NSS and is notorious for snapping off.
Take a look-see at that pointer. Is it there...or not? If not...it also loses tensile strength and falls off.
Well I think I am gonna take it apart tomorrow and put a volt meter on it to see if it is working or not. If not, then gonna go get another one. If it does, then I dont know what to do next.
I just went through this dance with my truck. In my case, it was the piece on the steering column that contacts the neutral safety switch that broke off when I replaced the shift collar (thanks ND).
