!948 F1 Engine options?
Old Aug 11, 2009 | 03:10 PM
twllin's Avatar
twllin
Hello everyone im new here. A few years ago i bought a 1948 Ford F1 from my grandfather for $1! It needs a new engine and probablly transmission. THe body is in real good condition and does not have much rust. I would like to get it running before i start working on the body. I want to Hot Rod it but i am wondering which engines can fit. It has the Fladhead 6 right now. But i would rather "upgrade" the engine right away so i dont have to do this later. I just dont know which engines are out there that will fit without having to modify the engine bay. I have tried searching but no luck yet hopefully you guys can help me out.
Old Aug 11, 2009 | 03:59 PM
dongc1's Avatar
dongc1
Depends on how far to the "darkside" you want to go and what you can get your hands on at a reasonable price.
I would stick to the small blocks to make it easier. Several people have used a 302 ford. You can probably find nearly anything if you look hard, but the big blocks like a 460 ford require a little more work. Of course you can go all the way to the far side of "dark" and use a sb c***y.
Old Aug 11, 2009 | 04:18 PM
4tl8ford's Avatar
4tl8ford
Engine options for a 1948 Ford F1
Flathead V8
Flathead I6
That's it.
Old Aug 11, 2009 | 04:21 PM
Old F1's Avatar
Old F1
Do you mean mostly the firewall? Most small displacement engines (302 etc) are not much longer then the original six.
Old Aug 11, 2009 | 05:23 PM
twllin's Avatar
twllin
Im new to all this. I guess since the flathead i have now has a crack on the block i was just thinking of putting something in with more HP. I dont really want to make too many modifications to the firewall or fenders inside. With a smallblock would it fit right in or would i have to make any modifications?
Old Aug 11, 2009 | 05:33 PM
dongc1's Avatar
dongc1
I don't know about anything but mine. It's a SBC and I did not modify the firewall or the inner fenders.
Old Aug 11, 2009 | 06:02 PM
twllin's Avatar
twllin
Which one is yours? How many Hp? Did you have to put a new tranny as well?
Old Aug 11, 2009 | 06:07 PM
dongc1's Avatar
dongc1
check out my gallery
https://www.ford-trucks.com/user_gal...hp?userid=4425
It's a stock 350 with a 700R4 trans and 9" rear end,
Had to mount the engine 1" off center to get clearance for the Toyota steering box.
Runs and drives great.
Old Aug 11, 2009 | 06:36 PM
twllin's Avatar
twllin
That looks nice thats the look im going for. If you dont mind me asking what did the engine and tran run you?
Old Aug 11, 2009 | 09:47 PM
denverslim's Avatar
denverslim
I would lean more toward the period correct 8BA flathead V-8.
Won't be the fastest,
Won't be the cheapest,
But it will fit in there like a glove and when yer uncle Joe looks under the open hood, he'll say, "Man, I remember these"...slim
Old Aug 11, 2009 | 10:44 PM
dongc1's Avatar
dongc1
Can't help you with the cost. I had part of it and then traded some stuff for more parts.
I did have a trans shop go through the 700R4. Cost me $325. Completely rebuilt the engine,
bored .030 over, polished crank, did the valves and put roller rockers on, new push rods, roller timing chain, new oil pump, new distributor, and who knows what else. Don't have a cost for engine since I did most of it myself.
Old Aug 11, 2009 | 10:49 PM
Snowking's Avatar
Snowking
I enjoy my 239s. cant beat the sound.
Old Aug 14, 2009 | 06:50 AM
3414's Avatar
3414
How about something really different? Like a 2.3 turbo and 5 speed from an 84 to 86 T Bird Turbo Coupe?. Should fit, will be lighter, can be economical to run with good performance when needed. Will definitely draw attention.
andrew1
2004 - 2008 F150
Dec 25, 2012 06:17 PM
armysoopertrooper
Apr 30, 2012 06:30 PM
72AmericanPR1DE
28
May 28, 2009 06:31 PM
fordman6.2
2009 - 2014 F150
Mar 15, 2009 06:42 AM
WoodN1_76
23
Apr 19, 2008 02:43 PM
