Sponsored by: Real Truck
Clutch problems
Old Aug 11, 2009 | 10:32 AM
honda400ex's Avatar
honda400ex
Question Clutch problems
Ive got a 2000 F350, 2wd with 7.3l. for the past day my pedal has felt a little mushing at the top and this morning while driving to work, i pushed it in to change to 2nd and the pedal didnt come back up. i pulled it out of gear and turned in a parking lot. i was able to pull the pedal back up but has since done it twice more. finally, the clutch works about 1-2 inches off the floor now. i checked the fluid and it checked out ok. i now the clutch was starting to slip after my chip and bigger tires but hasnt given me the slightest bit of problems, even towing 9000lbs loads. ive never really delt with a clutch so im hoping someone can give me a little insite on what ive got going on!! thanks for your time!!
Old Aug 11, 2009 | 10:48 AM
03_PSD's Avatar
03_PSD
Mine did the same thing, time to go to ford and get the pre-bled hydraulics for the truck.
Old Aug 11, 2009 | 11:43 AM
honda400ex's Avatar
honda400ex
is that just to replace all the hydro's for the clutch?
Old Aug 11, 2009 | 11:49 AM
12ozd's Avatar
12ozd
Exactly, couple bolts,couple clips and you're done.
Old Aug 11, 2009 | 11:50 AM
03_PSD's Avatar
03_PSD
yeah, just for the clutch.
Give me a second and I'll get the part number for ya.
Edit: can't find the part no. but its the pre-bled master/slave assembly from Ford. When I did mine it was around $215 with tax
Old Aug 11, 2009 | 12:50 PM
honda400ex's Avatar
honda400ex
awesome, thanks for the info. that beats doing the clutch. ill get to it this weekend and hope for success!!
Old Aug 11, 2009 | 12:59 PM
03_PSD's Avatar
03_PSD
No problem. If you run into a problem installing the new hydraulics let us know, we'll take care of ya!
Old Aug 12, 2009 | 10:33 AM
honda400ex's Avatar
honda400ex
i just ed talked to the Ford dealership out here, and they say they dont have anything like that. i have to order all the parts individual, any ideas??
Old Aug 12, 2009 | 10:51 AM
03_PSD's Avatar
03_PSD
Thats odd. You should be able to get pieces individually or buy the complete kit. If you can wait a little while maybe give FTE parts guy Ed (They are a sponsor) a shout and he'll get you squared away.
Old Aug 12, 2009 | 11:04 AM
honda400ex's Avatar
honda400ex
I just sent Ed a message, hopefully he can help. its at the point where the pedal has zero tension ( except the spring ) sits on the floor and wont go in gear at all.
Old Aug 12, 2009 | 02:38 PM
12ozd's Avatar
12ozd
Here's a tip for ya.
The new slave cyl.will come w/ a plastic retaining strap to hold the push rod in.
Do not cut the strap until after you have installed the cyl.
Seems simple enough,but alot of folks will cut the strap,then it can be a PITA to install.
Another thing to check while you're there;
There is a plastic bushing on the m/c push rod where it attaches to the clutch pedal. Replace it.
I can't remember if it comes w/ the new m/c or not.
Old Aug 13, 2009 | 04:49 PM
honda400ex's Avatar
honda400ex
I justed wanted to drop and and let you know the clutch has been fixed!! is was a hell of alot easier then i though it was going to be and i wanted to thank you for helping me identify the problem. it was the master cyl. but i replaced the slave too, just in case.
Thanks again!!
