94 F150 - fuel pump runs but truck won't start
Old 08-10-2009, 03:33 PM
R202INT
R202INT is offline
R202INT is starting off with a positive reputation.
Hello all,
94 F150, 4.9 5spd, 282,000 miles. Ran out of gas about 3 times in the last week. However, according to mileage calculations, I shouldn't have. (no, gas gauge doesn't work - not consistently, anyway). Anyway, I supposedly "ran out" yesterday afternoon, poured in 2.75 gallons, and had to turn the switch on and off about 7 or 8 times, before it would crank. Ran fine coming home, about 2 miles, but it did seem like it was trying to die out once, (for a few seconds), but continued running. Parked in the driveway, and went out this afternoon, but it will not start. Considered that it might have a hole in the tank, and had leaked out, but saw no evidence of this. Incidentally, my mileage has always been around 15.7 mpg, but after calculation, it showed it to be 9.02 mpg. This thing has really got me in a spot, as I am supposed to go back to work this Wednesday, after being out of work for about 3 months. Any help/suggestions would be ever, ever so much appreciated. (And no, I'm not interested in participating in "Cash for Clunkers" !!! I mean, Come On - it's a FORD! They don't run good till they get about 1/2 wore out!!)
Thanks
Old 08-10-2009, 03:49 PM
Popa Tim
Popa Tim is offline
Popa Tim is starting off with a positive reputation.
Do you have dual tanks? One tank could be pumping into the other.
Have your fuel pressure tested. Be sure to check the FPR for leaks, and do the bleeddown test on the injectors.
Old 08-10-2009, 04:13 PM
Volvo92906's Avatar
Volvo92906
Volvo92906 is offline
Volvo92906 is gaining momentum as a positive member of FTE.Volvo92906 is gaining momentum as a positive member of FTE.
fuel filter?
Old 08-10-2009, 04:31 PM
SaikotikGunman's Avatar
SaikotikGunman
SaikotikGunman is offline
SaikotikGunman is gaining momentum as a positive member of FTE.
Ditto on fuel filter change. If you don't remember it being changed recently, it's always worthwhile.
But that's probably not your problem. Check fuel pressure and pull codes if applicable, then work from there.
Old 08-10-2009, 08:44 PM
R202INT
R202INT is offline
Volvo92906, you are quite likely correct about the fuel filter. Friend of mine who does roadside repair on tractor trailers, came by and put his diagnostic scanner on it, but it would not give any codes. Said it was "unable to read" or something to that effect. However, he pushed the stem in on the fuel line fitting, and only got a little rusty gas, which smelt like it had been sitting up for several years. This was with the pump running. It more or less just dribbled out. So, I conclude that the inside of the filter has finally disintegrated and quite likely all of the sediment, trash, etc. it has trapped over the last few years, is now into the injectors. Anyhow, I cannot get the fuel lines to disconnect from the filter. Yes, I have the tool, same one I used to disconnect the fuel lines when I replaced the fuel pump a year or so ago. You can hear the bonnet spring release, but it will not come off of the fuel filter outlet pipe. The only thing I know to do is to try to spray some PB Blaster in to the line to lubricate it and the spring. Any other ideas?????
Old 08-10-2009, 09:00 PM
Volvo92906's Avatar
Volvo92906
(I work on tractor trailers too)
Umm. I would spray some PB on it also. Thats all I can tell you. I have butterfly clips or whatever on my truck. But, my first idea would be to replace the filter just because its easy and cheap. Kind of like checking the battery first when you have no power.
Good luck!
Old 08-10-2009, 09:47 PM
SaikotikGunman
My filter was held into those aluminum bells on the fuel line by some kind of retainer that reminded me of the parking brake cable clips that hold it in the frame bracket and drum. I forced them, not knowing what to expect, and ruined what was left of the retainers(someone else had mangled them once before and just crammed what was left back in there).
Took some tiny hose clamps, cut the screw adjuster off of it, and coiled the band inside that aluminum bell, used needle nose pliers to open it up inside there enough for the rib on the filter end to get past it, and then slipped the filter in, making sure it locked in.
I'll probably never be able to get it apart again, but I'll cross that bridge some other day. It doesn't leak!
2015F450
1999 to 2016 Super Duty
30
01-23-2016 07:17 PM
skizzo
EcoBoost (all engine sizes)
07-29-2015 12:37 AM
IDMooseMan
92
08-30-2011 02:15 PM
jinxie
29
07-24-2008 09:59 AM
laredo7mma
05-27-2008 10:08 PM
Quick Reply: 94 F150 - fuel pump runs but truck won't start
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
