i am currently running an autolite 2100 series 2-bbl carb on my stock 292. i have heard that you can use holley power valves and main jets to tune this carbs? does anyone know if this is true and can verify this for me? i am looking to tune it a little more, but have not found any kits to do so! thanks for your help!
It is true that the jets and power valves are interchangeable.
Power valves are numbered by the vac that it requires to hold them closed for both but I am not sure Ford and Holley use the same numbering system for the jets.
Gentlemen,
Thanks for your information! It is the helpful folks like you guys that make this site absolutely great! I'm glad to know what "bump to the top" means now, too!
