I have an 88f150 351w c6 4x4 that the fuel pump won't run unless I jump the wire from the self test connecter. even then the truck will not start..... unless I spray a little starting fluid into the engine then it will start AND run. if I remove the ground from the self test connector the truck shuts off like turning off the key. and ideas or suggestion are welcomed. thanks
