Cruise Control ?
Old Aug 10, 2009 | 01:27 PM
Brain's 97 Diesel's Avatar
Brain's 97 Diesel
Yes usually the center pin of the 7 pin trailer connector, unless someone else "played" w/ it.
Old Aug 10, 2009 | 04:24 PM
madpogue's Avatar
madpogue
Originally Posted by 48' fordster
Im running the 5 speed
There's also a switch on the rod that the clutch pedal pushes. Two switches in one. The two red/blue wires going to it are for the starter circuit. They should read "open" until you push the clutch all the way to the floor. The other two (don't know the wire colors; no EVTM handy) are for the cruise control. They should read "closed" with the pedal up, but "open" as soon as you move the pedal at all. You could, as a test, put a jumper wire between those two wires on the back side of the connector; just remember that when you do, the clutch will NOT disengage the cruise.
Old Aug 13, 2009 | 01:59 PM
95_Dually's Avatar
95_Dually
I also have this problem. I have the 5 speed and I was not aware of the clutch pedal switch. I will test it tomorrow. Thanks to all involved in this thread. Sorry .
Action4478
13
Feb 23, 2011 09:33 PM
skeeter4x4
Nov 6, 2006 05:19 PM
soutthpaw
26
Sep 19, 2006 12:06 AM
Clipper
1997 - 2003 F150
Apr 23, 2004 03:55 PM
BradB1221
Mar 22, 2003 10:37 PM
