'53 light duty 3spd verses heavy duty 3spd
My '53 F100 is equipped with flathead 8, light duty 3spd and 3.91 diff.. I have a 9" diff. with 3.25 gears that I want to swap with the stock rear. Also I might be running 16" stock wheels.(currently 15").
I recently acquired a '53 parts truck that has the 3spd heavy duty transmission. Would there be any advantage to running the HD transmission with my proposed setup? What is the drivability difference between these 2 transmissions?
First remember that 3rd gear in both is 1:1 ratio
The difference will be in 1st and 2nd gears - I don't have the ratios at hand but the term Heavy Duty usually means that 1st gear will allow you to drive up the side of your house or to take off with maxed out weight and get up tp 5mph before needing to shift into 2nd gear.
Unless you intend to work your Truck like Trucks back then were built for - the standard 3spd should be your choice for a driver.
Gear Ratios
Side by side comparison of light and heavy duty 3spd transmissions.
Source FOMOCO '53 Shop Manual.
Transmission--------Gear Type----------1st-----2nd------3rd------Rev.
3spd light duty------All Helical----------2.78---1.62-----1.00-----3.63
remote shift
3spd heavy duty-Helical-2nd&3rd-----3.71---1.87-----1.00----4.59
remote shift-------Spur- 1st & Rev.
Does anyone have any experience with the HD trans.?
remote shift
Without doing any of the math, I'm thinking that if you change from a 3.91 to a 3.25 you just might want the low first gear that the HD model offers. Check it out on any of the number of gearing calculators that have been posted here.
I will say this, I had a '55 Fairlane with 272 and 3 speed, and going from a 3.89 to a 2.90 was a HUGE difference. I had to slip the clutch a lot more with the 2.90 to get it moving.
i have the heavy duty 3 speed in my 49 with 239 flatiron. i've never driven with a light duty 3speed so i don't have any comparison. my 1st doesn't seem particularly loud (among all the other noises, ok, so i can barely hear the radio) but the spur gear non synchro part is obvious, no shifting into first unless you are virtually at a stop. dick r
mert, your tranmission looks quite different (heavier?) than mine. mine is in a '49 not sure if it's original but it does look like the one in my motor manual (manual says that the f-1 had a HD trans as an option). i didn't know i had a heavy duty until i looked for a speedometer gear, the part number on the old one was id'ed as from a heavy duty transmission. i have one piece drive shaft and the e brake on the back wheels. just learning about it now, trying to figure out which rearend gears are in it. dick r
MTFLat has this combo in a BonusBuilt, although he may have a 3.50. He also lives at a mile+ altitude and in the mountains, but he can give you an idea if you send him a note.
