Stranded in Indy(Danville, il) what tools do I need? Rear brakes on dually?
I do auto transport and lost a rear brake pad lastnight on my 99 dually. It just whipped it out totally and fell right out! I have some tools, what will I need to change this? I'm I. Indy now heading towards Danville, if your in the area and wouldn't mind giving me a hand. I would greatly appreciate. Reply here with your number. Thanks a lot guys
If your rotor is shot, the hub has to come off.
It's bolted to the inside of the hub.
You'll need the hub socket to get the nut off inside.
My F-550 has a different socket than yours, so don't go by the picture, go by the application for your truck.
I posted mine for illustration purposes.
It's a common tool that NAPA has.
Other than that, a socket set, a big C-clamp to compress the pistons.
Is there a problem with forcing the fluid back to the tank? Thats how I did mine. My tank overflowed, but that is all that happened.
Can't slap a set of pads on to get you where you're going?
If you gotta pull the hub,don't forget the seal.
av8tor09
07-09-2009 06:41 AM
Deebo54
11-07-2005 07:04 AM
rebelsailor
01-27-2001 11:44 PM
