Mercon V Mercon III compatibility / exactly what are differences?
Just need some input on exactly what are the differences on mercon V
versus mercon III or other dexron approved ATF.
Can a older transmission be completely flushed and updated to Mercon V ?? would additives be needed ??
I have heard conflicting stories on this subject.
You should not use MERCON V in a transmission that requires MERCON. Thos two fluids should not be mixed, either.
Always use the recommended fluid. There is no benifit from using MERCON V in an older transmission that requires MERCON.
If your reason for asking about MERCON V is because of synthetics, MERCON V is not necessarily synthetic. Some are, some are not. There are synthetic MERCON V and MERCON fluids on the market.
Mark
Mark
Mark, That sure helped me understand what the difference is, I sure hope Kevin does too.
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
John
jowilker email me
I bought my 1992 Aerostar 3.0 with 129k and black transmission fluid. I flushed and filled with Mercon V. (I later found out that Ford says Mercon V should not be used in the 1992). There was a great improvement in shift quality. Drove over 100k using Mercon V with no problems whatsoever. I recently changed to Amsoil ATF and this was even better - gears shifts are now almost imperceptible, even under hard acceleration, almost like driving a vehicle with a CVT type gearbox.
derek0525
08-12-2016 10:45 AM
