Need a wider rear end
When you have a dually, the front hubs have something like spacers that let you run bud wheels on all four corners.
A set of spacers would be a lot cheaper than custom axle shafts.
Here is a place that came up from a search, not bad price at 115.00 a pair, but that is only 1.5" thick, add 25 dollars makes them 2.5" thick.
http://www.ezaccessory.com/Wheel_Ada...8650-8650d.htm
Cheaper than a dually axle or custom axles.
on
1 Post
Dodge and chevy front DRW hubs look like fords but wont bolt up. The rotor on all three bolts the the back of the hub. Then on the outside of the hub is where the wheel studs are. Anyone know about van Sterlings? I hear they are wider. I have 3 but never bothered to look and id have to dig them out to see now.
I guess if u need me to I could go measure my dually sterling. Its a cab and chassis axle.
It would be easy to just put some bolt on wheel spacers on it though. I have some 3 inch thick ones on my van so I can run dually wheels and have never had any problems with them. Just make sure the lug nuts for them are tight from time to time.
