Oil in coolant
I would imagine that you would have a lot of water in your oil if a head gasket failed due to the pressure difference maybe a little oil in the coolantwhen it cools down. I have seen little bit of oil like substance in green coolant before, not sure what or why.
Before the wind leaves your sails, check the oil.
Oil in the coolant on a 6.0L is typically a sign of oil cooler failure. I haven't seen or heard of oil in the coolant or coolant in the oil on a 6.0 as a result of headgasket failure. Not saying it couldn't happen, but it would be VERY VERY rare. What makes you think it was oil? It can be exhaust particulates from the blown headgaskets making it appear to be oil. The coolant filters can get very nasty very quick.......usually within 500 miles they need to be changed.
Between the turbo and engine oil filter, but underneath the engine oil filter. I couldn't find a good picture to show it to you quickly, but I can tell you it's a pain to change because of the amount of things you have to remove to get to it. Check Ebay before pricing at the dealership. I know one shop that changed 6 two weeks ago on 6 different trucks. You should look in your degas bottle also, as this will easily show the oil. Automatic dishwashing detergent is usually the best thing to use to flush the cooling system out with because of it's low foaming properties.
This is from brickie ....
To replace your oil cooler:
The boost tubes, alternator, intake manifold, egr cooler and oil filter housing all have to come off. If its an 03 motor, the turbo has to come off to remove the intake. If you are used to wrenching count on the best part of a day.
It would be nice to have a good write up w/ pics on this for the Tech Folder - if you take on the job in the future!
BigGreenEx
08-02-2016 07:55 PM
1buckeyefan
03-29-2011 11:17 AM
